1988 Lincoln Town Car
    Napa = WIX btw.
      YEah 3.08 + HO + stock torque converter is not inspiring at all. Really needs at least a 3.55 to be acceptable, 3.73 and/or a looser converter would be better. A lot of it really is the converter. The stocker stalls at like 1800, the HO sucks under about 2500 rpm.
        I order from Rock Auto at least once every two months or so. I'll check into FL1A filters next time I order from there.
        NAPA charges criminal prices for stuff here, I'd rather take my chances on the Fram parts for now.
        Plan is to do a K-code this winter coming. Not going to mess with the torque converter until the trans comes out, which hopefully won't be for a while yet. It's fast, but I can totally see how gears and converter would wake it up even more. Still loses it in hills in OD, but once it kicks down to third, even going uphill you should hold onto your hat. Big difference from what it was a year ago. Sometime I do want to do a proper HO upper/TB combo, as I'm currently running a lopo upper with 86 Mustang TB and EGR bored to 58mm.
        It's a work in progress.
          Originally posted by nfldfordltd View Post
          ...NAPA charges criminal prices for stuff here, I'd rather take my chances on the Fram parts for now...
          Even if the filter is $30, why risk one of those shitty filters coming apart (let alone not catching as much particulate) and starving your engine of oil on a engine you JUST REBUILT? Not to mention what a PITA it is to get the engine out and all that...
            This is very true. It's just not worth the risk.
            I've been buying Motorcraft filters by the case for about five years now. All they sold at the BX on base in Germany was Fram, and the local stores didn't carry anything that would fit the Mustang. It's too cost effective to just use the sub-par Fram filters on a newly rebuilt engine.
            —John
            1985 Ford F-150 XLT Lariat
              I guess I shouldn't tell you guys that I run PowerFlo filters that I got a pile of for less than $1 each on my cars.
                LoL no, at that point you might as well just run an empty filter case..
                  they're actually Purolator filters, not near as bad as the cheap price would indicate. Dollar cost isn't the ultimate measure in determining quality.
                    Never said it was. However, you typically get what you pay for. If someone already did their homework to determine where a filter actually comes from and how it's internals stacks up then OK. Me? I don't have those connections. Weight is a good indicator.. It's not like they'll let you cut the filters open before you buy one. I ran A/C Delco or Motorcraft ones for years before I tried the Purolator Boss filters and noticed my oil remained noticeably cleaner for longer before I switched to 'em. At Meijer they were among the cheaper filters available.
                      I finally got around to starting a clean up on the Lincoln today. Hand wash, windows, vinyl (including roof), engine bay touch up and carpet/seat vacuum.
                      Tomorrow after work I'll be continuing with a carpet shampoo (including the carpet mats), clean the service rubber mats, tidy up the trunk and apply a good coat of wax. I think I'll have to go over the roof again as the first coat of grease for the year usually gets soaked in pretty good and needs the second one. Going out of town for a few days on Saturday so if time allows between now and then, I'm going to have a go at shining up some chrome before I go. The bright aluminum trim on the roof around the door/window frames is faded, me no likey that.
                      Then I'll be afraid to take it out into the sandstorm that is Goose Bay, for it will definitely get dirty again.
                        I need to wax my car. Needs the full treatment.
                          So my car has developed an annoying surge at idle lately. Only occurs when it's partly warmed up to normal operating temperature. Never happens when cold. Also, sometimes it's a bit hard to start when half warm/half cooled off after being shut off. It will always start, but needs some accelerator similar to when it's flooded. The surge is made considerably worse when the A/C compressor is cycling (when the HVAC is in the "off" position, it's a lot better). Occasionally, it's bad enough to stall. IAC is three years old, in good shape and recently cleaned. I haven't checked for codes yet, and vacuum lines all appear to be in good shape. I'm thinking my lower intake wasn't set in place properly when I had it apart to change the lifters and pushrods a little while back, it seems that's when it started acting up. I did remove the upper and checked the torque on all the lower intake bolts while the engine was warm, they were within spec. I tightened them a little where the bolts are old and possibly stretched a little, they are all at about 30 lb/ft now. No difference made to the surging idle.
                          I'm sure someone else here has had a similar or the same issue in the past...input appreciated as always.
                            See what's doing with a vacuum gauge hooked up to it or try and spray carb & choke cleaner around gasket areas while it's running to see if the idle changes any.
                              Check out the surging idle checklist on StangNet. Most people solve idle issues with it.
                              Updated 05 July 2022 to add rough idle when cold and smooth idle when up to normal operating temperature. See the EGR tech information, section #15 for more help. Many of you are familiar with the "Cranks OK, but No Start Checklist for Fuel Injected Mustangs" checklist and the No Crank...
                              —John
                                Any chance you got the oxygen sensors reversed? The idle can hunt if that happens. Can also happen if the ground is off at the back of the intake.
