View Post
Derek's 1988 Town Car
2005 Volvo V70 Bi-Fuel
I kept bumping the wiper arms lower, and the slop just kept getting worse and un-fixing my fix, until I discovered what was actually at fault. YMMV.
Newer years like this should have the cast metal (unclear what metal, but some sort of metal) pivot assembly with 2 screws rather than the earlier plastic part with 3 screws. If you do have the metal one, I'd certainly try just clocking the wiper arms lower. While you're there, shoot some sort of oil into the pivot assembly (ideally both). It'll turbo charge your wiper speed.
This is touched on in this reply and a few above and below it, plus a video link: http://www.grandmarq.net/vb/forum/te...29#post1235989
Your double-reply suggests you're using a browser where you haven't fixed the settings for HTTP+HTTPS mixed content for the site to work properly. Highly recommend doing so if you're able.
Originally posted by kishy View PostI kept bumping the wiper arms lower, and the slop just kept getting worse and un-fixing my fix, until I discovered what was actually at fault. YMMV.
I'll have to check that video link out, a little confused about the clocking as I didn't think you could do that with the wiper motor. Guessing you can just clock the arm and not the wiper..1985 LTD Crown Victoria - SOLD
