So way back in late 2012, I inflicted some damage on my car when I clipped the garage door frame. It put a small dent in the door and messed up the door moulding, knocking off the small dogleg piece and bending back the door trim.
Well between then and now I had gotten a trim piece and attached it to the door. However, I had little experience with automotive paint at the time, and attempted to spray the trim with Duplicolor without any primer, nor any clear coat when I finished. The result was the piece was too dark and not too long later, the paint started to chip off, showing the light blue color of the original piece.
On top of the paint being shitty, the chrome insert had a crack form on it, which resulted in some of it de-laminating and turning gray. All in all, it was terrible.
Well, I finally got motivated to fix it. It's not paint shop perfect, but it's still a heck of a lot better than what was originally on, and I've actually put both pieces on to finalize this area. In the case of this job, I started with a Duplicolor Base White Primer, then used Duplicolor Primer Sealer, followed that with the Toreador Red, and finally used Krylon Acrylic clear coat. After it dried for 24 hours, I was impressed with the finish as it was, even though a gentle wet sanding will be sometime in the future.
Replacement on top, replacement for the replacement on bottom:
Attached:
I've got to do some minor adjustments since it looks like it may be sitting a touch low towards the B-Pillar, but it does look considerably better. There's some spots on the chrome where the paint got under the tape, but I've already cleaned a few places on it. Overall, I'm much more pleased with how it looks now than it did.
Attached:
