Originally posted by MrMarquis
View Post
2007 Grand Marquis LS "Luxoliner"
My Cars:
New meats on the Luxoliner.
We had to make a spur-of-the-moment trip to Florida for my grandfather's funeral, logged close to 1700 miles on the old OEM Michelin tires. The rears were balding and had very little tread. I've been sitting on the fence about the steelies and haven't really done anything with them, and this trip forced my hand to buy new tires.
I went with a set of Continental TrueContacts, same size as stock. TireRack reviews are mostly positive and they are reasonably affordable. Supposedly 90k tires, at least the warranty extends that far. From what I read, the wet weather performance is excellent; winter reviews look good as well. White wall tires were more only available in the older series tire and more expensive...so farewell to the pinstripes.
Whole car needs a bath and the tires need a good shine, but here's the new look. Gonna take some getting used to.
I think it looks great! I was never really a big fan of the white walls, I mean yeah sure they're alright on a box-styled body (and not just those made by FoMoCo), but on a reasonably modern-looking car like yours here they just look kinda outta place. These Contis on the other hand make you car look very much like a '96-'97 Town Car, which IMHO was one of the classiest vehicles Ford ever made. For the same reason I think it's not a bad thing you didn't do the steelies, these wheels just look right on this car, to me steelies should only go on el-strip and/or hot-rodded Crown Vics, they got no business on a Grand Marquis.The ones who accomplish true greatness, are the foolish who keep pressing onward.
So I realized today that there is much less space in the front of these cars than the boxes...
I'm working on plans for an onboard air system for the whale. I was really hoping to use my old horns that I just pulled off of Cherry, but there is no way in hell that they'll fit behind the grille of this car. The cross member in front of the radiator severely limits room to work. I hate to say it, but I may have to go with one of those plastic Hornblaster sets...I much prefer metal, but the trumpets will have to sit side by side to fit without major modification. The old set will be set aside for the truck I suppose. But I really want noisemakers again.
Current plan is to reuse my Viair 480C compressors, pumping out 200psi to a 3-5 gallon tank. I'm trying to make everything as non-invasive as possible, with limited holes through the trunk. Everything will be secured to inner sheet metal. If I can find a suitable aluminum tank, I'll go that route; but, it must fit on the side ledge in the trunk and I'm struggling to find one of correct size that's rated for 200psi. A 20" 5 gallon tank is going to be a squeeze but readily available in steel...or I could do a dual tank setup and stack two 2-2.5 gallon tanks, not sure yet.
As with anything, my progress is usually extremely slow. But I did pick up a 4x8 sheet of particle board to cut the bases for everything out of, and I'm researching copper lines and fittings to hard pipe everything in the trunk. DOT air line will run down the frame to the horns. I'll most likely use an electric valve instead of my manual one to avoid cutting into the passenger compartment. Not really any good space to set a big air lanyard anyways. I've got 50 feet of 6 gauge wire ready for my runs to the trunk. I'm determined to do a better job than the guy that installed my first system.
Picture unrelated, but current state of the car.
Heads-up #1, you don't really need 200 psi. Big trucks rarely exceed 150 psi, and you know how loud their air horns can get. Also, to build up 200 psi it's a helluva workout for the compressors, 150 or so is much easier and helps with their life span. May wanna check the rating on the air line too, should be way up there but depending on where you source it from it can get a bit so-so.
Heads-up#2, check the orifice size of the e-valve you wanna use. Mine is really tiny inside, it's fed by a 1/4" line like many road tractor horns are, but the valve itself must flow quite a bit less than the line can - yet it's plenty for the pair of 3" Grovers it feeds (you've heard them). My other setup consists of quad 6" Grovers, those got the lanyard mechanical valve and larger air line just cause of the air flow they need. So, lots of horns, or big horns, or lots of big horns, you need either one larger-orifice valve, or multiple smaller valves. Also keep quality of build in mind, my e-valve leaks down good 40-60 psi overnight from the pair of IIRC 5-gallon tanks, but it was cheap as heck, and I use up air all the time anyways so it doesn't bother me much.
If you can wait a few weeks, pay me a visit and bring your car for fitment - I got at least once big Grover road tractor horn I'm not gonna be needing, it's not train horn loud but does make people jump for the bushes or lay on the throttle to gtfo the way
Edit: your truck is an I6, all sorts of space in that engine bay for the real train horns - I strongly dislike when they're installed on the frame, they see all sorts of crap down there (especially if truck is 4x4 and used as such), and they're vulnerable from physical damage too. Engine bay is where they need to live, or in your case they can also go on the Racerback as well, but IMHO that would look tacky as all heck, and it will be hard on your own ears as well. Air tank can safely live on the outboard side of the passenger-side frame rail, especially since you have no dually fender braces or camper tie-down beams or other such obstacles. Handle valve location should also not be hard to figure out, it's a big cab with lots of space.Last edited by His Royal Ghostliness; 06-16-2017, 11:21 PM.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by His Royal Ghostliness View PostHeads-up #1, you don't really need 200 psi. Big trucks rarely exceed 150 psi, and you know how loud their air horns can get. Also, to build up 200 psi it's a helluva workout for the compressors, 150 or so is much easier and helps with their life span. May wanna check the rating on the air line too, should be way up there but depending on where you source it from it can get a bit so-so.
If you can wait a few weeks, pay me a visit and bring your car for fitment - I got at least once big Grover road tractor horn I'm not gonna be needing, it's not train horn loud but does make people jump for the bushes or lay on the throttle to gtfo the wayAnd there's no way I'm fitting Nathans in there...
Right, I forgot the Hornblasters setups actually do resemble the sound of real train horns, in that case carry onSee I keep forgetting you're not just after loud, but it needs to be a very specific kind of loud - whereas I care for loud and where I can fit it so salt spray is not gonna eat it alive in a winter road trip or two, so the big truck horns do the trick for me just fine.
Also, car or not, I think you actually do need an air horn systems, matter of fact everyone does. It seems to be about the only way to get the attention of the mobile-deviced retards we gotta share the roads with. Like that one fool who decided to stop at a green light for no good reason i think about a week ago, it's not like I wouldn't have been able to stop on time behind him but the blast of air seemed like a more proper response to the situation, and it sure got him going quickThe ones who accomplish true greatness, are the foolish who keep pressing onward.
Yeah, there's really nor much space to mount horn shenanigans on aeros and whales.
R.i.p.
Well, Luxo met his demise this morning as I was coming home from work. A woman pulled out from a side street right in front of me, not even looking my way as she tried to jump into a line of traffic. I was able to swerve a bit to avoid straight T-boning her, but there was no way to avoid it outright. I got her with the front corner and tore the front of her car off.
Cops had to push her car off onto the shoulder with their cruiser. I backed the Marquis onto the side road dragging the damage along with me. Cops got a kick out of that, as they were unsure how to move it otherwise.
In reality, it's probably repairable. Bumper actually didn't seem to take much of a hit and the airbags did not deploy. Hard to say if it tweaked the frame any though, couldn't really dig through the damage that well. Her insurance has already said that she was 100% responsible and I'm waiting for the adjuster to make the call at this point. I'm fairly certain they will say it's a total loss though.
What's left of her Camry.
With that, I'm Pantherless for the first time since Jan 2006. Browsing Craigslist for a replacement so I'm not driving our brandy new Explorer daily into Atlanta. We knew moving down here that our probability of getting into an accident would skyrocket. It only took nine months.
Thanks for the sacrifice Luxo, it's been fun.
Sorry about the car Scott. Glad your ok. Not sure what the insurance will do, it really depends on the company. Back in 2015 when I had insurance work done on my 2001 Town Car the estimate was $2,000, insurance valued the car at $7500. I thought that was a bit high but obviously wasn’t going to argue. I would think today a clean 2007 would be worth at least that. If it is totaled I wish you luck finding another nice panther.
Sorry to hear about the car. Does look repairable. Insurance Co may say differently. Always interesting to see what they say.1990 Country Squire - under restoration
Sucks Scott.
Was the rear wheel well and rear passengers side door damaged from this accident as well?~David~
The more south yougo, the worse the drivers.
People in upstate NY were so much better drivers.
Sorry about your car. That stinks. At least your ok. Definitely fixable if you want to.-Nick M.
Columbia, SC
The more urban you go, the worse the drivers too. DFW isn't much better than Atlanta.
