1985 CV - A Canadian 2bbl 302
    I have a snakedriver specifically for getting at weird access screws. Came in very handy when I had the 85 b-body with a q-jet.
      Good call... I have one of those too. The snake driver, not an 1985 B-Body... used to have one though... 1985 Caprice. Good car, until I crashed it. Ah, to be 18 again...
      1997 Crown Vic - Mostly rust free, moderate mileage. On the road... but far from perfect. **SOLD**
      1985 Crown Vic in 2-Tone Blue **SOLD**
      http://automophiliac.blogspot.ca/
        "Where's my Honda?"
        "Sorry babe, I had to crash that Honda."
          I did the double filter gasket thing once on a boat. It was a top mounted remote oil filter. Fired it up and it pissed oil everywhere, all over the upholstery of a 1 year old boat. I spent the entire rest of the day detailing that boat to get all of the oil out of the seats, carpet, and out of the engine bay. Cars suck far less in that regard, at least it just gets oil on mechanical bits. Just imagine if the oil filter was inside the car and that happened.
            Well, it's certainly nice to hear that I'm not the only one who's had some oil issues!
            Update:
            New Oil filter was Fu-kayed thanks to the double ring action. Replaced it. Got new egr plate gasket and new carb mounting gasket installed. Sourced replacement mounting gasket from local parts shop.. fel-pro. Took some pictures to illustrate the thickness difference between stock and the mounting gasket that came with my kit... it's about 25% thinner.
            Got that all installed and discovered that the threading on the fitment that attaches my fuel line to my fuel filter on the carb was worn out and it was leaking gas all over my intake manifold. Got some thread sealer from my dad that he uses on his boat. Let it sit for four hours and that did the trick.
            Also, and this is the BIGGEST news, I figured out my fast idle cam indexing while the carb was off! My choke pull off wasn't pulling enough, so I adjusted it, reset the idle screw and syncronized things with the coke plate opening and it all works amazing now! No more constant fast idle and she runs great!
            Still a little hesitation on fast throttle from slow/stop, but all in all working really well. Tranny shifts awesome too! It's nice to have things finally working well. Next job is attacking some of the rust spots over the winter and cleaning up some of the trim. Also, next year is new exhaust time!
            WOOT!
              Here are the pics I snapped while I was working on the car over the weekend:
              Carb is off the car. Makes it way easier to mess with the fast idle cam. But now that I know what to look for I think I could do it on the car now... which is nice.
Name:	gasket thickness comparison.jpg
              You can see how much thicker the stock gasket is compared to the one that came with the rebuild kit. The one I now have installed matches the stock thickness. Really cut back on boiling gas in my carb.
Name:	gaskets installed close.jpg
Name:	gaskets installed.jpg
              These are some shots of the gaskets installed. The colour of the EGR plate gasket is a light gray and the one that came out is black, but they seem to be made of similar material.
              That's all for now.
                Cool. Figured there had to be something a bit goofy there. Didn't realize the pulloff had an adjustment screw. Carbs really ain't my thing. I know them decent enough in theory, but its those little details that are important.
                  Yeah there's a 1/4" hex head in the back of it. Twist it to the left for more pull and to the right for less.
                  Drove the car to London again, this time there were no hiccups at all. No hesitation or anything. Just no balls! lol But what do you expect for 130ish hp (when new) and 2 tons?
                  Next year is new exhaust w/ my fresh from Georgia Lincoln Logs, maybe some rust repair to the body. Then in a few years I'll do the head swap, new cam, 4bbl conversion and some suspension work. Should probably upgrade the brakes too... just better performing pads and rotors, nothing crazy.
                  If I ever need to do some rear end repairs, then I'll ad the limited slip but I'll leave her as is for now.
                  She won't be a 12 second car or anything, but at least she'll get out of her own way!
                  Long-term saving up for a late 1960s big block galaxie fastback. it'll be my 45th birthday gift to myself.
                  PS - there's a definite hissing/whooshing sound coming from the direction of my brake booster. It happens when the brakes are applied, but also sometimes when the throttle is applied. Any thoughts?
                    Might be the the auto parking brake release valve.
                    I'm sure there's a topic here on it but the one on CVN is stickied: http://www.crownvic.net/ubbthreads/u...38#Post1452538
                      Thanks! That sounds about right. I looked at it briefly the other day and found where it was. Can't seem to find where the hose goes through the fire wall though... it's attached to a hard shaft (giggle) not a hose. I will remove it another day and see if the vacuum hose going through the firewall is routed through the shaft.
                      Just a question about interior trim though for the folks who know... do your boxes have the stuff under the dash exposed or is there supposed to be some sort of interior panel to cover this stuff up? It looks like there may be spots for this stuff to screw into the dash, but it also might never have come with it. Just think the mess of wires is a little ugly... but that's just me.
                        Wonder if my brother's '87 GM has one? I never drive it so don't know. Can't say as I remember an auto release, though. Just remember him pushing the pedal to set it and pulling the handle to release it. Would think it doesn't have one but a confirmation would be nice...
                          Ash and I crawl around at junk yards all the time and Town Cars seem to be the only boxes with a cover to hide all of the stuff under the dash.
                            That's good to hear. I would hate to think that i'm missing a third of my dash!
                              my 88 MGMGS and 93 CVLX have the carpet shields to hide all the under-dash ugly.
                                Hmmm, maybe I'll keep an eye out for some ugly hiding carpet shields on an MGM or Towny.
                                On another note... gotta adjust my hot curb idle up a little. My alternator charge is a little low, so when I come to a stop the light comes on. If it revs ever so slightly the light goes away... so... hopefully a straight forward fix. I still have to see about plugging that vacuum line, but that can wait for now. The car's going into storage soon so I'll fiddle with cleaning some trim pieces, adding little touches here and there. I'll post as it happens!
