Saved from the crusher!
That's an HPP with a small dent in it if anyone's interested. Looking for a steel 15 and decent tire to swap, maybe with $40 cash as well? Michelin HydroEdge tire with plenty of tread left.
So this car carries a good number of firsts for me;
-1st time adopting the previous owner's name for my car
-1st car I've ever owned with full leather seating (my Genesis Coupe had cloth inserts)
-1st time I've owned a car with factory-installed digital gauges
-1st car I've owned with digital gauges that ACTUALLY WORK
-1st Lincoln. Ever.
-1st car I've owned with air-ride suspension
-1st car with a keypad to open the doors. Man, I love keypads. Why don't more cars have them?
-1st time ever buying a car I've known for a good amount of time before pulling the trigger.
Oh, and
-1st used car I've ever bought that's OBD-II
The Good:
-NPI engine with revised heads that don't smoke like a chimney
-Better MPG than my Grand Marquis, based on owner history and fuel logs
-Meticulously maintained by PO - oil changed every other month, regardless of mileage
-A/C works AMAZING. SO COLD. Best air conditioning system I've ever experienced in a car I own
-Fresh shocks, fresh air pump, fresh air shocks, fresh greasable ball joints - suspension is proper
-In spite of body rot, the frame and underbelly are very clean
The Bad:
-REJECTED inspection sticker due to bad passenger side exhaust leak, MIL reporting a 'lean' condition - likely due to the leak throwing off the O2 sensor readings
-Heater core leaks bad and has been bypassed - and winter's right around the corner
-10-year old BF Goodrich Traction T/A's and Michelin X Radial have good tread but a lot of sidewall rot. Moderate chance of blowout on highway driving.
-Broken driver's rear window regulator. Has already been serviced, so at least the rivets were replaced with nuts and bolts.
-Driver's door bushing is shot. Gotta slam the door to close properly. And because of this, the handle is getting loose and may fall out.
The Ugly:
-Driver's corner lens is destroyed, need a new one
-Paint clear coat is shot
-Passenger's fender is rotted out, need a new one
-Driver's quarter panel behind the rear door has a rot hole
The cost:
Title swap for my 1993 Grand Marquis. No money exchanged hands.
So... did I make out a winner this time?
-1st Lincoln. Ever.
Oh, and
The Good:
The Bad:
The Ugly:
The cost:
