I considered a '95 that color when I was shopping for my GMQ. Passed it up because it had rust, straight pipes, and I didn't really want another red car. Yours is in a lot better shape than both the CV I passed up and the GMQ I ended up getting. Sweet!
The 92 CVLX pt. II
1995 Grand Marquis GS - 156k miles, three-tone until I find my paint
1990 Toyota Camry DX - 211k miles, someone else's future barn find
1994 Saturn SW2 wagon - wife's car
Originally posted by SVT98tI'll make it fit.
I own hammers.
woohoo! My memory works!
Originally posted by 79lincolnlover View PostYes I doNo cracks in it.
Too far to just go and fetch it.
I'd look at it (the car) myself but too far to drive it back.
Pulled the old trans yesterday, swapped over the governor to the rebuilt trans I pulled from my old 91 GM. Looks like Ford just slapped an HO high speed governor in the bastard blocks. Also have a 2k stall convertor laying around I'll throw in, I figure a stock box one would only make the no low end 4.6 that much worse.
Today I repaired the pass side bulk head and ran some new brake line, new lines to both fronts, and a new line from the splitter to the m/c. They were originals and very sketchy looking to say the least. At least this car doesn't have the ABS clusterfuck like my old one did. Rear line was replaced and looks ok still. Fuel lines have also been patched and look okish for now.
Pass side bulkhead after cutting out the rot: I actually ended up cutting some more off so I could more easily weld a plate over the hole on the inside part of the rail.
And after a lot of cutting, welding and grinding, good as new:
Originally posted by pantera77 View PostLooks like Ford just slapped an HO high speed governor in the bastard blocks.
Now to see how much the junkyard will charge me to pull it. If they even will.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
Sweet 92 zack looks great I'm sure you will end up driving it this winter
Thanks Gabe.
After getting the trans in yesterday made a JY run today. Grabbed non leaking p/s reservoir, some spare headlight clips, and a heater hose, no 92-97 aero Vic's in the yard unfortunately, just TC's and GM's. Oddly a few where HPP's and I saw 3 HPP whales. Also swapped in my 87's blower motor resistor. Sure glad Ford never really changed much on these cars.
Anyways I took it out for a quick run down the road and back, drives real nice, no squeaks or rattles, trans shifts great, 4.6 runs smooth as butter. Alignment seems decent, heat works good, A/C is unplugged, guy told me the compressor is shot, it's still full of R12 though so I probably won't dick with it.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Registered it and transferred the plates from the Battle Wagon onto it today. Took it for a nice 25 mile drive. Runs great, shifts great, handles surprisingly well, alignment is good, and stops damn good too. I'm honestly impressed by it. It's so quiet and smooth I found myself doing 15+ over a few times. Threw the check engine light twice, got home and got the paper clip out, good ole code 33. Jeez I wonder what it could be causing it....
I'll clean out the EGR passages and slap on a new fuel filter tomorrow maybe.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Selling it or keeping it?
Originally posted by miamibob View PostSelling it or keeping it?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
92 part deux! Not bad for 500. I like how clean it is.
