85.03 Crown Vic Coupe "CVGT"
    Your progress makes me sad because I haven't made progress like that in months. Looks good.
      Originally posted by sxcpotatoes View Post
      The white Tudor box body, I thought.
      That indeed it is. Modbox without the mod motor mistake.
      Originally posted by SVT98t
        Frame looks fantastic! What sort of applicator are you using? Foam brush, rollers etc etc?
        Promise me that you will remove the two door off the frame in a more gentle manner...No chains through the doors please.
          So that's all the same length? What are the advantages to putting that frame on it?
            some people like the rack and peanut steering. I do like the watts link in the back, but not an R&P fan.
              I wounder if the same thought process will will work for the town car/coupe extended wheel base frame.
                Good luck finding a Town Coupe. They are amazing, but uber rare.
                  Update from this afternoon.
                  Grant wheel came in, I picked up all of the Ni-Copper line that I ordered for fuel and brake lines. Got head gaskets, blue thread lock, high tack, pan gasket. Then I spent some big bucks. Ordered the entire set of rotors and pads from a local brake shop. Street Plus Performance, my dad has them on his '12 E350 van and his E31 BMW, both of which are drilled and slotted. I've driven both and am thoroughly impressed. So I ordered DOTTED and SLOTTED rotors, which will also be getting dipped in a rust preventative. Thereafter, I bought all four pads from him, they're significantly cheaper thank Hawks ($60 vs $90) and comparable. So I'm pumped.
                  Don't mind that, I'm waiting until the car is on the frame and then I'm going to pull the aluminum cross member and perfect that entire portion of the frame, doing it the correct way.
                    You'd use a Towncar frame. Same wheelbase.
                      So uh I got all the brake lines done, I just need to get the fittings and flare em. I think the lines came out pretty good but not that great to me; can always be better. Fuel return line is parallel in 1/4" line.
                      Still waiting on my damn body mounts to come in.
                      On a side note, I was planning to start putting my engine back together tonight but then I got a little side tracked and got all of the machinist tools out, experimenting with porting my heads (GT40s). They're not done yet but at least all the castings are gone. I made a little jig to hold them on an easy to reach angle on my work bench. I used a carbide bit to hog out the castings and then wooden bit to smooth them out, they'll look much better when I'm done. Hell I know they won't do much but it's worth the experience.
                      Don't mind all the texture on the paint, the second coat was laid on very heavy.
                      I will need to pickup a set of gaskets and figure out how far I can hog them out.
                        Lookin' good man, real good. Had drilled/slotted rotors on my '98 and didn't even know it until I got tires put on it. In 5 years I only had to put rear pads on it but the rotors were fine and the damned thing stopped like nobody's business. You'll be very happy with that setup. That's really the only thing I miss about my whale. I'll get back to that someday. If you're going to a great deal of trouble, why not shitcan the gt-40s and put some REAL heads on that sucker? I'm a cheap bastard, and poor, but I'm willing to spend money on good stuff for the motor because I only want to do it once. I dunno, everyone has different priorites.
                          Because I'm going to likely build a stroker motor for the car and aluminum heads can wait. Especially since this motor is only going to be used until I finish building a new one. Unless something goes tragically wrong and this one has to come out. But she did good for the first 7,000 so I think it'll be alright.
                            Fair one, doubt you'll hurt that motor in the meantime. Stroker=fun.
                              Looking good, so much easier to run those lines while the bodys off! Did you say you used 1/4" for the fuel line? That's too small for the power you are making based on what I'm finding, this doesn't even list 1/4":
                              * Up to 375HP = 5/16" or -04 AN
                              * Up to 550HP = 3/8" or -06 AN
                              * Up to 800HP = 1/2" or -08 AN
                              * Up to 1200HP = 5/8" or -10 AN
                              Take that chart with a grain of salt though, a lot of mis-matched info online, however no one seems to be running 1/4 on anything that makes decent power.
                              -Phil
                                The 351 ran pretty damned good as it was, so I don't think this'll hurt. Just don't pull a zoomie and port the water jackets, guy..
