nah, all my stuff runs on electrosity.
85.03 Crown Vic Coupe "CVGT"
Well here's the update.
Mocked up the cross over, mounted the alternator (Made my own bracket) need to find a foxbody powersteering pump bracket (Identical to the one Thain posted). I put the real turbo on (GT45) it's about 15lbs heavier than the small one that was on it.
Raised the radiator support up (took 3" out of the whale mount.) Made the lower radiator hose, put a different thermostat housing on an a foxbody upper radiator hose.
I also made the core support cover. Got sick of the shitty looking factory core support so I went to the metal yard today and bought some sheet metal for some things. It's got farther to go, but I love it already.
Blow off valve, intercooler piping, down pipe and oil feed/drain are the next steps.
Then engine replacement and injectors. Thereby the start to final assembly.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Originally posted by packman View PostWhoa...........that's a lot of work!!! Gonna be something when it's up and running
Probably broken again.
Or another blown T-5.
03 Mercury Marauder- 63k
I like the idea of the core support cover. Ive contemplated multiple times bringing home a few of those plastic aero/whale covers and making something happen. Always bailed out though after a test fit proved unsuccessful.~David~
yeah I would like a cover plate on mine too. Lincolns have a lot of space up there, so it would make a perfect tool shelf in addition to hiding all that ugly shit that lives below it. Would also keep me from losing sockets in the damn rad support or between the radiator and condensor on the regular.86 Lincoln Town Car (Galactica).
Pure awsomeness
For the core support cover, I'd make a template out of cardboard, and then have that laser cut out of aluminum sheet.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by P72Ford View PostFor the core support cover, I'd make a template out of cardboard, and then have that laser cut out of aluminum sheet.
Got tired of not having a proper tool shelf, since It's a yearly endeavor to massively change the car.
Picked up a powersteering bracket set and pump tonight. Now working on stripping my donor motor and will probably pull the rotating assembly out of it tomorrow night. Then pull the motor out of my car.__________________________________________________
I was thinking powdercoated or painted panels as well. Never been much a fan of shiny things under the hood of cars that actually get driven. Too much bother to maintain it, time that could be better spent driving.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI was thinking powdercoated or painted panels as well. Never been much a fan of shiny things under the hood of cars that actually get driven. Too much bother to maintain it, time that could be better spent driving.
I may just bedline it.__________________________________________________
For duty as a tool tray that actually makes good sense.86 Lincoln Town Car (Galactica).
Powdercoated aluminum. So when it gets scratched it doesn't rust. .
Even I wouldn't polish it in this application.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Well since I haven't updated it, in sometime now.
It runs, spins the turbski and pushes air. Currently in the process of modifying the transmission mount for my new transmission. Then I'm going to need my driveshaft modified and a new flywheel/clutch.
I cleaned up the engine bay wiring again, all wires now come from the back of the engine and into the valley. I always hated the look of shotty wiring dangling off the sides of the engine. Fuel lines have also been moved back, so that they don't hang off the side of the engine as well. I've mainly been focusing on all of the custom fabrication that needs to be done. Crossmember needed some very heavy modifications, maybe I'll post some pictures when I'm done. Waiting on Vbands and piping for my turbo down pipe. I also order some Polyurethane resin and will be trying my hand at pouring my own rear control arm poly bushings, after getting dicked over by CHE. I've also been putting a lot of time into details with the car, since I'm not in a big rush to get it driving, like in years past.
Realistically I won't be able to drive the car much, when I'm away and working this year. So maybe that'll allow me to tinker on it, instead of overlooking problems and letting them get worse and worse. Probably won't ever be the daily driver again. But would like it to have all the comforts and reliability of one.
I need to get the radiator top mounts figured out, intercooler piping, wrap all of the exhaust, fix and paint my lightning upper intake, swap out the fuel pump, finish the crossmember, patch up the trans tunnel and utilize a stock foxbody shifter lower boot, sort out the hydraulic slave cylinder for my clutch on the new transmission.
That short list doesn't include the body work for the roof, figuring out what the issue is, if there is one; with my rear diff, the entire interior and lack of seats. Cutting a hole in a hood, preferably not my factory white one.__________________________________________________
