85.03 Crown Vic Coupe "CVGT"
    passengers side header was a breeze because you cheated. lol You had no smog and ac systems in your way.
    Yeah! I kinda thought the same. Hopefully if all things go right, It'll be ready for SF. 351 and all.
    Though it's nothing special, just another box CV with a motor that other models came with, just slightly upgraded.
    But I kind of want to bring the whale, since we're doing numidia, curious to see what the JMOD would run.
    Originally posted by SVT98t
      Originally posted by Bobcat View Post
      Todays progress........
      Cut the bit of the stud off, drilled out the hole and put in a bolt then put that header in, bolted up the H-Pipe and it seems it will need a 4" piece of straight pipe between them to connect them........
      4 inch pipe to connect to the mids before the mufflers?
      Oh and bring the tudor. I think we will have 4 of them there!
        It's a BBK H-Pipe from a fox and there's a point in between of where the H-Pipe can bolt together, instead of one piece.
        There's a two inch gap in between them, when installed. I may just have to force them together but I just left it as its.
          Ahh I understand now. Your H is not connecting.
            yeah... the H pipe the shop put on my car has an added section of pipe in the H to make up that gap. For yours, you might be able to make up the gap if you loosen the nuts on the header flanges to allow some movement and then work them together and then tighten up the flanges again.
              .....4 tudors ? , ......ok you, me , possibly panterra.....who else?
ID:	1275900Maybe the boy from NYC
                  I may do that when the 351 goes in, otherwise I'll just put a pipe in for now. That is if I even end up driving it before the 351. Somewhat unlikely as is.
                    Originally posted by toploader View Post
                    [ATTACH=CONFIG]40165[/ATTACH]maybe the boy from nyc
                    all the tudors
                      oh cool!...awesome!
                        Nice buy!!
                        '79 Continental Town Car
                        '90 Crown Victoria LTD
                        '94 Crown Victoria
                          too bad I can't come up in the Lincoln... ALL THE TUDORS!
                            Love to see that Mark VI.
                            So.. KYB shocks came in today, may install tomorrow or today if I get bored.
                            > Fixed the drivers side window which seemed to have not wanted to seat in its frame right. Man the doors are huge.
                            06 needs an LCM (has needed one..) So I'm attending to that currently. Thought of rewiring the LCM and use an external relay but it's alot of work when I can just not be a cheap bastard and order a LCM.
                            Here's a interior picture and the engine bay picture when I bought it.
Name:	photo 2 (2).jpg
ID:	1275902Click image for larger version
Name:	photo 1 (2).jpg
                              Dave, Dave, Zack. Logan and now possibly toploader. Yikes. No hitting any other cars with our big ass doors okay.
                                Lol. Need to source some mufflers for the car before driving is even in the question
                                3.08 open would make for a good ride down there on the highway though. I guess that's one good thing about it..
