Originally posted by Bobcat
View Post
85.03 Crown Vic Coupe "CVGT"
Disc not drum
Originally posted by pantera77 View Posti can't stress how important this is. Don't be a fool like me and turn all your vehicles into project vehicles.
b.t.d.t.
Originally posted by sly View PostDisc not drum__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Originally posted by mitymerc View PostAre the 92+ axles different than 91?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
I used goofoff for the glue on the doors/fenders. Surprised it didn't mess up the clear coat. Flashes off quickly but did a nice job. The paint is just a slight bit whiter now where the strips were protecting it when you look at it close in the sun.sigpic
89 LTC 429>557 Cobrajet stroker
13 F-150 XLT 6.2 l
"If I could separate what's real from what I've been dreaming I could live to fight another day"
So are the disc axles physically different from the 91 drum axles?
Bobcat, this is turning out to be a vicious beast!
Other than the drums and backing hardware and possibly the brake lines/ parking brake cable, no physical differences 91 to 92
Thanks
Originally posted by mitymerc View PostBobcat, this is turning out to be a vicious beast!
Update:
Started it up and broke it in today. Sounded great and idled good, had to take periodic breaks to adjust the rocker arms.. Still need to do the passenger's side, they're not-as-bad. Blip the key for a second and it fires right up. All systems a go. Gotta take out the T5 since I forgot the clutch fork and throwout bearingGot my firewall clutch cable adjuster today, need to drill a hole in the firewall and all that jazz. Soon soon it'll be drivable.. Hell.. Yeah...
Yes.. I know about the camber on that driver's wheel.. I need to put the shocks in still and adjust all that. I just wanted to see what it'd FINALLY look like with front tires..
Before and after of engine
Needs:
Fuel regulator
Driveshaft U-Joint
Calipers
Brake lines
and she's set. Also need a new shifter handle, that short shit; aint gonna fly.Last edited by Bobcat; 03-16-2015, 12:08 AM.__________________________________________________
You should also look into a round knob, t-handles lead to missed shifts...
Since you are taking out the T5...do yourself a favor and take it apart, it doesn't take long, and check the shift fork insert, the tailshaft bushing, and the synchros...-Phil
What do you need a clutch for? Learn to flat shift itIf you're good, it won't even damage the trans. It is a bit hard on the starter having to crank-start from every stop light though.
