I have 4wd hubcaps for that pickup. I had a 96 F350 with plow.
85.03 Crown Vic Coupe "CVGT"
Originally posted by Mainemantom View PostI have 4wd hubcaps for that pickup. I had a 96 F350 with plow.
Originally posted by packman View PostPull 351W out of F-250 (depending on year, '95-'97 roller block) and install into CV with better parts (go-fast)? Then install 460 into F-250? Not practical for the F-250, but would be fun.
and the 94-96 was the roller block, that's what mine is.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Originally posted by Bobcat View Post
Just start calling him everyday and reminding him. He loves when people do that86 Lincoln Town Car (Galactica).
Truck appears to be rust free?
Is it a stick?
Needs a D60 swap, and white steelies with agressive treads.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by P72Ford View PostTruck appears to be rust free?
Is it a stick?
the EGR tube was non-existant. Manifold had this tub coming from the back that came up to the top of the engine in the rear, not hooked to anything.. Hmm.. Has 4 new plugs and wires (Haven't gotten to the rest yet)..
Picked up a new tire for the 06, used Pirelli scorpion. Likes to spin alot easier than my BFGs.. One tire is starting to show threads on the inside. Car is sold and I told the guy that I'd atleast fix the shredded tire. Plans to put snows on it anyways.__________________________________________________
check for a melted converter. That will make it do that stuff. For extra fun, the test is to unbolt the exhaust an go for a rip. If it doesn't find the problem, at least its fun.86 Lincoln Town Car (Galactica).
Originally posted by Bobcat View PostIt's a choked out 351 that stalls at WOT and can't climb hills... Trying to figure that out..
Looks like a nice truck, a lot better shape than ours and probably much more worth fixing.
1995 Grand Marquis GS - 156k miles, three-tone until I find my paint
1990 Toyota Camry DX - 211k miles, someone else's future barn find
1994 Saturn SW2 wagon - wife's car
Originally posted by SVT98tI'll make it fit.
I own hammers.
Originally posted by gadget73 View Postcheck for a melted converter. That will make it do that stuff. For extra fun, the test is to unbolt the exhaust an go for a rip. If it doesn't find the problem, at least its fun.
Originally posted by rezwrrd View PostSounds a lot like my family's '79 250. Still haven't figured it out. Trying to sell it to somebody who actually knows what they're doing, and has money to do it. Ours works fine up to about 35-45mph, but stalls if you give it too much. As the engine warms up, it stalls lower and lower until it won't run at all.
Looks like a nice truck, a lot better shape than ours and probably much more worth fixing.__________________________________________________
When was the fuel filter last changed? Clould be clogged up, acts like it does with a clogged cat, could be either, those are the first two I check when it's bogged down.88 Town Car (wrecked, for sale)
I've been planning to bang on the cat or just take it off to see if it'll run better.. It's got brand new fuel lines and a fuel filter from the last owner..__________________________________________________
pressure test would tell it too. if the line inside the tank is cracked or the pump is half shot, you'll see it.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postpressure test would tell it too. if the line inside the tank is cracked or the pump is half shot, you'll see it.
` Lapped the valves on the 'new' 40 heads, they already have new springs, valves and seals. They weren't too bad but I lapped them anyways.
` Chased the head bolt holes out on the shortblock, need to go buy a helicoil for one that was stripped by the past owner..
` Installed one head, oiled the bolt heads and followed proper torque pattern and specs. 351 - 95lbs 302 - 65lbs must be all that power, needs to be contained y'know?
` Painted most of driver's front portion of frame rails with gloss black.. Pretty.. still need to do passenger's side and disassemble the LCAs and UCAs
May go to the salvage yard tuesday since no school (woo...) See about a 79' wagon they got in that's untouched. Then may go to another salvage yard to pickup BB parts..
Raw thoughts, don't mind my rambling__________________________________________________
351's have larger bolts. 1/2" vs 7/16".86 Lincoln Town Car (Galactica).
