It's been a long time since I've written here. Lots of personal crap, problems and obstacles and everything inbetween. I'll get right to the point.
The water pump was fine, just to get that out of the way. The radiator hose needed tightened. It's fine now.
Since the last post, the following has been done:
-Air conditioning leak fixed
-Replaced the gas tank and everything attached to it but the sending unit and hanger assembly. Turbine fuel pump, new fuel filter. New fuel pump works well and does not sound like it wants to explode.
-Brakes cleaned, brake fluid flushed and replaced with DOT4; brake fluid was 4% water, which was the problem. Have a bunch of new brake parts I didn't need. Oh well.
-Hardened stainless lug nuts. Turns out only the nut is stainless, the cap is not. They're already rusted. But at least I will be able to get them off. Two of the caps actually came off, so I had to replace those nuts.
-Changed the oil with Royal Purple HMX 5W30 and used Liqui-Moly engine flush. Wix XP oil filter. This finally UNLEASHED THE BEAST WITHIN.
-Replaced the battery cables with SGX 2-gauge high density weave copper cables and Allstar gold-plated brass terminals. New terminal covers as well. Had to use the old chassis ground. Cleaning that off fixed the flickering lights.
-Tied down the battery with a ratchet strap. Now it will stay put. The KUNG sound I would hear on large bumps was the battery hitting the hood. Were it not for the insulation, that would have been very bad.
-Got the windshield leak filled. Turned out to be a rust problem, but since I addressed it quickly I shouldn't have to deal with it for a while.
-Replaced the MAP sensor. Found a NOS Motorcraft unit for $37. Solved some of the hesitation and vastly improved fuel economy as well as smoothed out the powerband.
Next up is the motor mounts, the throttle position sensor, and the vacuum hose that goes to the MAP sensor. If the TPS doesn't solve the problem, I'll have to move on to the fuel pressure regulator. I'm also pretty sure I should address the ball joints soon, maybe the idler arm. After all of that's taken care of, I'll put in a 3G alternator, and then start saving up for a Silverfox AOD-450. I'll flush the engine again in about 3000 miles.
I've also learned a huge amount of stuff. Because of this, I've massively amended the stuff I want to do.
-I don't think I need bigger brakes. These ones work great, so it wouldn't be worth it to me to do the big brake conversion, solely because of the cost of new tires.
-I also don't think I need 31-spline axles. I won't be making more than low-300 horsepower, maybe 400 torque tops. I don't think the cost and added weight of new axles and matching diff are worth it. I will instead get better 28-spline axles.
-I've abandoned the idea of a supercharger. My goal is to break 300 to the wheels, and that is very doable with this engine naturally aspirated, for not a whole lot of money. I've seen an article with ported GT40Ps and a Performer intake with a Voodoo cam making 367, and that was carbureted with a stock ignition, no underdrive pulleys or anything. A supercharger would be a massive waste of money.
-Instead, I'm going for high-compression naturally aspirated. Maybe 10.5/1. That should still run on 91 anywhere. I'll use an Anderson PMS and dyno tune it.
-Speaking of ignition, I'm keeping the Duraspark and will instead use a Pertronix Second Strike ignition box with a plain Motorcraft coil. I'll use a FAST Crank trigger ignition with it.
-I have changed my mind about a brush guard. It's enough of a tank as it is, the weight of a push bar would be superfluous, heavy, and just make it that much harder to park.
-I no longer want LS fenders and cornering lights. These would just make my front blinkers harder to see. The front headlights are more than enough as-is, especially once I put in a relay.
-On that note, I will be keeping the sealed beams and just using a relay. More than that will just be obnoxious.
Other than that...I just really want someone to re-mount and restore this dash. The rattle is starting to wear on me. That and the seats need tightened.
I no longer have any way of taking photos myself, so instead, here is a spoon.
