So the new steering box / pitman arm worked out great! Drove out to Montaulk the next day and the car didn't drift all over the place on the way there. Woohoo!
Problem is, my exhaust leak became a full on break in the pipe right before the muffler on the ride home. I'm guessing on of the bumps I hit on Sunrise hwy finished it off.
Here is the break while still in the car:
Here's the pipe after i took it out:
The exhaust leak was originally coming from where the pipe "y"s together. The metal was as thin as paper and basically folded in my hand.
Here's the new cheap Walker pipe replacement:
So this job should have taken all of an hour with some cursing and heat. I do want to go dual exhaust but was looking to buy some time until then by just buying the $30 Walker y pipe and replacing that as the muffler back looks good and so does the cats forward. The weld job was terrible on the new pipe. I had my friend hit it up again and reinforce it. The weld almost had holes right through it from the factory. Just for the heck of it, I hit it up with some caliper paint to maybe buy sometime on the rust as well. The original Y pipe didn't look that bad when I bought the car not even two years ago...
Trying to rush the install (aka "fucking up") I couldn't get the original Y pipe out of the muffler. It after prying and pulling I managed to get it flush with the muffler opening. Thinking a quick fix would be to put the new pipe around the muffler, I used the pipe expander tool on it. I wasn't able to get it wide enough to fit over the muffler so I ran down to a muffler shop to expand the pipe. They ended up not expanding it enough. (Just needed a liiiiiittle more space). That was my fault though because I didn't have the exact measurements with me. When I got home, I tried using the pipe expander again to get that little bit extra I needed. (By this time the shop had closed). No luck there, the tool stripped out on me. I must have already used my "one time use" on that Harbor Freight tool earlier.
During lunch today I just ran down to another muffler shop and had them open up the end a little more. Hopefully now it will fit. It may not be the best fit because I know it's suppose to go inside the muffler, but as long as it's somewhat quiet I can live with it for now.
Hopefully the next post here will be after a smooth install....
