I spent a couple of hours after work tonight lowering donor body onto the ground then took some measurements of the 2 cars to compare how much work will have to be done. At this point it looks like the 85' body will simply bolt onto the 07' frame with no modifications. My main concern was the 4 body mounts at the front of the firewall but they measure out to be in the same locations. Actually I discovered that Ford did so little work to these cars over the years. For example the 07' has holes in the firewall that are used on the 85' for bolts.
Box bodies have longer windshields which stretch down further onto the firewall. I was hoping the wiper cowl would simply bolt on but I will have to do some mods to get it to work.
