sounds like the clog (or excess oil at the time?) is in the hose from the dryer to the compressor... or the low port on the compressor.
there is something about setting the gap between the clutch plate and the drive plate. If its too far, it will not pull in and operate, or it may just let the compressor slip and barely work. If you've got voltage to the clutch coil, that sounds like the issue. If no voltage, check the AC WOT relay, both pressure switches, and the relay on the board in the climate control unit itself. They apparently un-solder themselves sometimes and it won't give any power to the compressor.
If the compressor isn't actually spinning, pressure on both sides will be close to equal and it will go up together. If the compressor was engaging and you had 60 and 90, it sounds like the orifice tube is missing, or has a massive leak around it. Or the compressor just doesn't work.86 Lincoln Town Car (Galactica).
I put the compressor back in the car tonight, didn't charge it up, just shorted out the 2 pressure sensors. Fired up the car and ended up with a huge puddle of oil on the floor. That's when I realized my supercharger oil feed was unhooked. FML! Anyway, hooked that up and cleaned up the mess then checked again and compressor was working. This is good news, no idea why it didn't work initially though... I also blew compressed air in all of the lines to make sure none were clogged. Could rusty clutch been the cause of all the problems?
might have been. The clutch is magnetic and rust doesn't help that function.
Works just like a manual transmission clutch really, if the pressure plate is all shitted up it won't grab properly. May have also been that the bit thats supposed to move had some rust sticking it, and when you pulled it apart that hunk broke out to allow it to work again.86 Lincoln Town Car (Galactica).
Originally posted by Mr Bean View PostI finally have working a/c! Evacuated the system and charged it up tonight.
2011 Ford Ranger Sport 4.0 2wd - Magnaflow Axleback exhaust, K&N 63 Series CAI, DiabloSport 87 Octane tune, LEDs, 3000K LED projector fogs, 5000K Mini H1 projectors - Daily
1967 Ford Galaxie 500 Sedan "C-Code" - 289 2bbl/Cruise-O-Matic - Money pit/project
So nice.
Should throw some marauder badges on it, I'd say it's worthy.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
I still say you should 4v swap it, and throw that old 2v in the rauder.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
cool... if I knew what to put on mine, I'd just use that pic and fill in the spaces. Mine was absolutely shredded when I found it in the springs of the passenger seat. There wasn't much left and what was wasn't readable.
Never have found it on the 93. The only thing I haven't had out of that car is the carpet and dash. So I don't think the build sheet is still in that one.
