    Looking good!
    That paper in the windshield looks familiar, is that the build sheet from under the driver seat?
    Vic
      Big "tip of the hat" to you as this is SO much work and coming along VERY nicely!!! Bobby
        really liking that interior work. nicely done
        Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
        Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
        Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
          Ok guys I could use some brainstorming ideas. While checking the seat fitment I realized that the seats are tilted towards the doors. I think Aeros and Whales have slanted floor pans or something. So I need to figure out how to raise one side of the seat up about an inch.
          I thought about using box seat rails but after quick inspection scratched that idea. What would be the best way to raise one side higher up? The only thing that comes to mind right now is to make a couple of spacers and using longer bolts. Anyone have any ideas?
            Spacers would be the first thing I would do. Simple, and easy to reverse if you run into snags with it.
              Yeah, I would think some sort of shim system might work.
                you wouldn't happen to have the tracks installed on the wrong seats would you? I know the early boxes used the same tracks between left and right, maybe the later ones were different?
                  something along the lines of an aluminum (or similar) bushing. i know what i have in mind. just cant describe it
                    Mhmmmmmm
                      Yea, my box seats have same rails on both sides. Whale and Aero seats have lower track on one side. I found a couple of spacers at Lowes. Was test fitting them the other day. Looks like they should work.
                        I stopped by Serge's on the weekend and got to check out the Mod Box. This thing is going to be totally badass - as if it wasn't obvious from this thread, it is way awesomer in person. Too bad about the bodywork required...but I'm confident the finished product will be outstanding.
                        Serge: I talked to my buddy (40 years auto body) yesterday about the seams in the B/C pillars. Check out 'metal-to-metal' (aluminum-reinforced epoxy) and Dyna-Hair fibreglass filler. Both are waterproof solutions that will hold up to moisture, unlike regular body filler.
                        RyPow
                        1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
                        1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
                        1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
                        2007 Lincoln Town Car Signature Limited, 102k, daily driver
                        2006 Mercury Grand Marquis LS, 115k, winter beats
                        1977 Lincoln Continental Town Car, 42k
                        2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
                        2015 Toyota RAV4 XLE AWD (better half's)
                          Thanks Ryan. I've actually used the metal epoxy before. It's good stuff. Maybe I'll give that a try.
                          I haven't really posted any updates in a few days but I am still working on the car almost daily. I welded up all the holes in the roof and started color matching the interior black. Today I went to a junkyard and found a minty black box Lincoln Town Car. Yanked a set of rear seat belts out of it. Couldn't get the front ones out, bolts were seized. If anyone have a set of black belts for an Aero or a Whale, let me know. They need to be in good shape though.
                            Goodbye faux wood, hello faux stainless steel. lol
                              Nice, that'll go much better with the newer dash.
                                nice.
