    It could definitely be a normal amount of moisture for sitting that long. However when my car had bad intake gaskets, the coolant turned the oil into a milky sludge. The coolant in the radiator remained clean and free of any oil.
      I already have gaskets on order so will change them anyway.
        I would be doing a compression and leak down check on that engine. Might find that is just an intake issue. Or, no issue at all.
          I am starting to wonder if perhaps it's from sitting all winter and moisture just accumulated in the engine because the coolant looked nice and clean.
          That's what I'd bet.
          You should see the Battle Wagon's oil if you want to worry. In the winter you could make gallons of cream cheese with what's under the oil cap.
            In the winter, I take the cap of the 4.6, and sling the crap on to the ground. Splat!
              I went totally ape shit on bignslow tonight. Started pulling the motor and tranny out when it decided that the center of gravity will be in the rear and then fell backwards pulling the crane with it and smashing the license plate cover while spewing the remains of tranny fluid and coolant all over the garage floor. So it looks like I will be taking the nose off to get the drivetrain out. No big deal except one of the corner light bolts decided not to come out soon enough. That's when all hell broke loose and I ripped the corner light out of the fender and proceeded to smash it into millions of pieces. I called it quits for the night because I was too pissed off and didn't want to break any more shit.
                I love breaking stuff and regretting it seconds later.
                  but you also have plenty of replacements to make up for it too
                    Sometimes I throw tools as well as breaking shit. I've thrown parts too. Of course all was done while having a fit of tourettes.
                    '93 T-bird
                    '03 Silverado ECSB
                    Missed:
                    '88 Mark VII
                    '86 CV
                      Temper temper temper. At least you stopped or you might have to attend the next anger management class in your area.
                        I don't often throw things, but I will refer to those things as "pieces of junk", even if it's not really junk but just being stubborn. Applies to 90% of the things I have and will ever own.
                        I might throw something that is definitely broken beyond repair. I mean, it's already broken.
                          Can we have a moment of silence?
                          If you look hard enough through the junk you will find a tudor.
                            Hmmm. Too bad those fenders aren't Twilight Blue. Cuz then I'd want 'em.
                              You could always paint them. That's what I did. One was green the other was pink. lol
                                If you wanna stash them til STAP, I would probably take them off your hands. Assuming the price is right.
                                See if they'll fit in the trunk of the Tudor. If not, forget it.
                                Would they fit in my back seat?
