85 Crown Vic Tudor
    Originally posted by BuffaloRider View Post
    Awesome!
    I was just trolling around the site and stumbled onto this thread...........read every post..............amazing! Just have no words!
    My '86 MGM Tudor is sand beige, but looks to be darker than yours.
    At 87K miles mine looks like it has gone through the wars of a NYC parked car..........if I could do a quick resto and have it look like yours, I would be supremely happy.
    Good luck she is amazing!
      Zach, I hope you are bringing it to STAP.
        +1. You know how long it's been since I've seen a nice, clean Tudor?
          That's the plan, if not, you know what I'll be in.
            There were two beige colors on box CV/GMs. Is your vinyl roof a lighter shade than the paint? If so it's like mine, darker beige with lighter vinyl.
            Zach, I have no doubt this will be another work of art like the rest of your cars. Keep up the good work! Your '89 is one of the main sources of inspiration for my 5spd Tudor project.
            RyPow
            1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
            1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
            1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
            2007 Lincoln Town Car Signature Limited, 102k, daily driver
            2006 Mercury Grand Marquis LS, 115k, winter beats
            1977 Lincoln Continental Town Car, 42k
            2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
            2015 Toyota RAV4 XLE AWD (better half's)
              Nice work! What color and kind of paint did you use for the accessory brackets?
                Thanks, but this car is kinda a pile up close.
                VHT cast aluminum, I like factory colors.
                "gauges" mounted:
                Factory trans cooler and p/s cooler mounted,
                  That tach is so ridiculous, I love it. What's the resolution like? does it count up by 500, 100rpm?
                    If memory serves me correctly I believe the retro gauge does oil, volts and water temp. o sure if it ALSO served as a tach.
                      Where did you get that? Its the perfect sort of thing to fit into that Towncar CD player console I've been meaning to turn into a gauge cluster for several years. It looks so very 1980s.
                        Yep, just the typical 3. Not sure if I'll even do a tach though one would be nice.
                        Looks like the guy I bought it from is all out. The fact it looks so 80's is the reason I bought it. I doubt it's super accurate, but it's fairly compact and looks at home in the car.
                          Nah, he's got more, new listing. Just search "Equus 6270" and you'll find it.
                          I may or may not have bought one, even though I absolutely don't need it (91 with functional temp gauge, oil pressure gauge already mounted, and voltmeter is when I notice the lights dim...)
                          | Junkyards
                            The gauge trio looks good there. Def would fit awesome in a grey interior. I have an extra, still in the package(I bout two of them, over the winter).
                              I see all of the tranny coolers mount crooked like that. Just a slight tilt upwards towards the passengers side. Mine mounted up the same way. Nice work Zach.
                                Ya, they mount silly anyways, thanks.
                                Little more work done under the hood.
                                And.......
