My $600 1989 Lincoln Town Car Signature Series(Beverely)
thank you slymer i will purchase that next week.
1982 Lincoln Continental Mark VI Bill Blass Designer Series 2-Door(Larisa)-Mods: HO Roller 302, GT40P Heads, Explorer Intakes, HO ECM(D9S), Autodimming w/compass and outside temp rearview mirror, Daniel Stern Lighting Mod, Dual Exhaust, 90's GM C/K Series Retractable Hood Light, Red Digital Dash Display, 92-94 White Leather Town Car Signature Cupholder Armrests, HPP Wheels, Police PS Cooler, Police Trans Cooler. More to come!!!!
time for an update my lincoln is now smog shit free it feels a little peppier now. all smog stuff is removed except for the tubes that go to the back of th eneads which will be removed once i get the GT40P heads bolted on. vac lines are plugged. i noticed i left one of the vacuum lines unplugged near the brake booster on this 3 way tee and the cruise control didnt work so i hope after i plug it i should regain cruise control as cruis control even though mine is integrated into the ecm it still should have a vacuum operated part too.
cruise control works again and i think i found out today that my water pump developed a small leak on the bottom. great i fricken hate doing water pumps on these cars. should i get remanufactered or brand new one. i am hoping the leak doesnt get worse until i switch out the cam.Last edited by MattsLincoln; 01-04-2012, 11:58 PM.
im going with a HD unit.
thought I had a leak on my 88's water pump. upper radiator hose needed to be tightened. Check all the hoses first. Tighten up the clamps and run it a few days. If the leak is still there... THEN change the pump.
I've never gotten lucky enough for it just to be a hose.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
if i he still has them doug vanstrom has two waterpump on his shelf one is an HD unit and the other is an edelbrock 25 bucks for either or. you can contact doug through the website link is in my sig89 townie, mild exhuast up grades, soon to have loud ass stereo....
i gonna contact doug about them. also checked it out today on a lift it's definitely the water pump leaking from the weep hole so fuckkkkkkk why does this happen in the winter. im gonna freeze my ass off doing this but i have no other choice. so i plan to replace the water pump, hoses, and fan clutch. im not bullshitting with the timing chain cover because i dont have a harmonic pulley puller.
Originally posted by MattsTownCarSS View Posti gonna contact doug about them. also checked it out today on a lift it's definitely the water pump leaking from the weep hole so fuckkkkkkk why does this happen in the winter. im gonna freeze my ass off doing this but i have no other choice. so i plan to replace the water pump, hoses, and fan clutch. im not bullshitting with the timing chain cover because i dont have a harmonic pulley puller.
