time for an update. i am in the process of prepping the cars frame to make it rust and rot free for the snow coming ahead. i used por 15 products and sandpaper to get my frame to be clean. started by treating the frame with marine clean then metal ready and then finally por 15 rust preventive paint. so far it came out nice i have half of the frame done due to the lack of good weather. tomorrow is suppose to be nice so i will finish up the frame tomorrow. i used the sand paper to sand down loose and flaking paint and rust. today since it is raining i pulled the lincoln into the garage and started to por 15 the trunk floorpan. pulled up the caret to see not a speck of rust occuring i was shocked. so i just marine cleaned the floorpan then let it dry then applied my first coat of por 15. after that coat dries i will apply another and it should be done. in nice weather i also plan to pull out the interior and carpet to por 15 the floor pan inside the car.
anyways heres pics of my process. oh and this is all painted by hand with a paint brush i dont have fancy spray guns.
