My $600 1989 Lincoln Town Car Signature Series(Beverely)
    smog delete belt is 56 inch. I have that on my Mark and 88.
      thank you slymer i will purchase that next week.
        What do you need a pulley for? Bypassing the smog pump and retaining AC is just a matter of a shorter belt...
          time for an update my lincoln is now smog shit free it feels a little peppier now. all smog stuff is removed except for the tubes that go to the back of th eneads which will be removed once i get the GT40P heads bolted on. vac lines are plugged. i noticed i left one of the vacuum lines unplugged near the brake booster on this 3 way tee and the cruise control didnt work so i hope after i plug it i should regain cruise control as cruis control even though mine is integrated into the ecm it still should have a vacuum operated part too.
            cruise control works again and i think i found out today that my water pump developed a small leak on the bottom. great i fricken hate doing water pumps on these cars. should i get remanufactered or brand new one. i am hoping the leak doesnt get worse until i switch out the cam.
              I would get a new one. They are not very expensive. I would do the job now. Do not wait.
                im going with a HD unit.
                  Make sure it isn't just the lower hose leaking at the pump. Been there...
                    Hey matt check ebay out first. My car being pre 89 had the HD pump from the factory. But I got a new not reman motorcraft pump off ebay for $15 with free shipping and it even came with the extra two bolts for the HD pump.
                      I used the $15 Valucrap last time around. Can't speak for its longevity, though.
                        thought I had a leak on my 88's water pump. upper radiator hose needed to be tightened. Check all the hoses first. Tighten up the clamps and run it a few days. If the leak is still there... THEN change the pump.
                          I've never gotten lucky enough for it just to be a hose.
                          Past Panthers
                            if i he still has them doug vanstrom has two waterpump on his shelf one is an HD unit and the other is an edelbrock 25 bucks for either or. you can contact doug through the website link is in my sig
                              i gonna contact doug about them. also checked it out today on a lift it's definitely the water pump leaking from the weep hole so fuckkkkkkk why does this happen in the winter. im gonna freeze my ass off doing this but i have no other choice. so i plan to replace the water pump, hoses, and fan clutch. im not bullshitting with the timing chain cover because i dont have a harmonic pulley puller.
                                You can "rent" or borrow the Harmonic Balancer Pulley puller from AutoZone or another part store. Put down a deposit, return when finished using & get your deposit back. Very good resource for tools like that you only need once in a blue moon.
