Mine are fantastically adjusted. They've not had a single problem in the 7 years or so that they've been off the car.
The MegaMerc
Originally posted by gadget73 View PostMine are fantastically adjusted. They've not had a single problem in the 7 years or so that they've been off the car.
The Blue car hasn't used a drop of oil since I parked it. (5 years ago).
I freakin' HATE Pep Boys. I went there out of convenience knowing that they usually suck. Ordered brake pads (on of their "customer service reps" looked up the pn , my wife went to pick them up & the woman ("Manager") argued w/her, tried to force her to buy rotors "you can't have the pads unless you buy the rotors", gave her a total load of crap, then finally acquiesced & sent her home w/the WRONG part. The pads turned out to be from a Chevy truck. The guy that got the pads & rotors must also have had a bad day. I went back between jobs yesterday, no MOD. A "lowly" parts counter guy was polite, respectful & apologetic. It obviously does not flow down hill @ that store. He found a set that he thought might work in stock (after looking @ NAPA & Rockauto sites) & sent me home w/Ceramic pads for $11.
Soo, I got up early on my 1st day off in a month & they don't fit, I didn't think they would, but it was worth a try.
Driver side signals stopped working today... No click, no flash on instrument panel. Both lit up solid. Park & sig filaments both lit up when signals are selected. WTH?
For lack of anything better to try I went to my local used parts emporium (basement) and got a flasher unit. Bingo! I don't think I've ever seen one fail quite like this before....
An easy fix is a win.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by mitymerc View PostDriver side signals stopped working today... No click, no flash on instrument panel. Both lit up solid. Park & sig filaments both lit up when signals are selected. WTH?
probably welded the contacts together internally. Fair bet that a solid whack would make it go for a little while until it welds again. Once that happens its pretty much toast though. The contact material is usually pretty burned and pitted and its on borrowed time.86 Lincoln Town Car (Galactica).
I tried whacking it w/a screwdriver before I went looking for another one, no dice...
My wife needed to drive the MM today. She said it "popped" once before it stalled. restarted after 4 tries, then stalled again when parking it. It would not restart, she could hear the fp.
I just got home & gave a cursory look @ the wires, cap & rotor, nothing of note. It started on the first try. I'm thinking TFI, can the part stores test them? Now that I have verbalized (typerized?) I realize it is not a hard failure so that would be inconclusive anyway....
Hmmm
I'd be pleased if it was your TFI. Since mine popped a couple times and then stalled, last time it ran. So that'd be a pleasant fix. If it's just that...__________________________________________________
TFI or pickup is a fair guess. Swap the distributor and see if the problem goes away. Last time this happened to me, the magnet fell out of the pickup in the distributor and it quit. Got one hitch, a pop, and that was all she wrote.86 Lincoln Town Car (Galactica).
Um, uh oh....
Bobcat, I have had no time to get in here for the last few mos, I did see that your project has taken an interesting direction!
I couldn't tell you if this test procedure/info is accurate but it might be worth a try:
http://351winsor.com/joel/Ignition_Systems/tfi2.html
I wonder if 351windsor.com was already taken?Vic
Originally posted by mitymerc View PostBobcat, I have had no time to get in here for the last few mos, I did see that your project has taken an interesting direction!
Yeah it's interesting and a real pain in the dick at times.
Mine popped a couple times and then stalled while driving down the highway, proceeded to then do a massive back fire and wouldn't start, thereafter.
It had spark but it seemed like the firing order was wrong or some shit, since it back fired out the intake when I sprayed carb clean in. Even though the timing was all correct.__________________________________________________
