Creamy
    very nice
      The finish, and attention to detail is AMAZING.
      What do you use to polish like that?
        Ceramic coating?
          The headers are ceramic coated. Think there was a thread a while back on polishing metal think everybody decided on Brasso. If I had what I stated in that thread back in 1970 I could have polished my brass so fast I could have spent an extra hour or two at the NCO club.
            The rest of the piping
Name:	DUAL QUADS 005.jpg
              Originally posted by turbo2256b View Post
              One advantage to this is no jacking up the engine or starter removal.
              This sounds like an EXCELLENT advantage. And there are those who say individually-flanged tubes tend to make for a better seal. I don't want to ask how much $$$$ and/or time is represented there, but I really like it!
                The rear end
Name:	REAR END 006.JPG
                  How many engine configurations has that car gone through?
                    4 I think including stock will get into that some later
                      Transmission bit of a mistery bot think it has the guts, tail shaft. tail shaft HSG and front pump from a 4R70W. I know a AOD slip yoke wont fit neither will a AOD torq converter. What I do know is there is a B&M shiter hooked to it, a Lentec valve body installed as well as a B&M deep pan
                        Time to pop the trunk. Just to make it leagle in IMSA, SCCA, ARCA.
                          I done forgot about you having a fuel cell. Must be convenient having all that empty space where the stock tank was.
                            I have plans for that space
                              Very nice stuff.
                              Any idea what the average primary tube length? What's the reasoning behind where they end?
                                Originally posted by johnunit View Post
                                Very nice stuff.
                                Not shure about actual tube length I know they are not truely equal length. They are much more effective than most aftermarket stuff though. Main reason for that is that no are bends coming out of the flange at the head. Spacing under the car has some to do with were they end along with placing of the X pipe and cutouts. Sometimes think an H pipe might have been better than the sharper bends to form the X. Then again just fllip a switch and the cutouts open and a car as quiet as stock in seconds is transformed to open headers and unrestriced flow.
                                BTW the cutouts are not currently installed. Nailing it with things closed has bent the flap on several ocasions and one time even broke the shaft into 3 pieces on one. When they were working opening them turned heads and there was that WTF looks on faces atthe drags, car shows, autocrossing etc.
