My 1989 Lincoln 557 cobra jet project in progress
    Mind if I ask how much those Moser axles ran you? Beefy.
      All Moser custom 31 spline c-clip axels are $295 a pair.
      89 LTC 429>557 Cobrajet stroker
      13 F-150 XLT 6.2 l
      "If I could separate what's real from what I've been dreaming I could live to fight another day"
        considering stock replacements are about $125 per... that's a good price.
          yeah, sounds like a case of "might as well upgrade" even if you don't need it.
          And of course with a 557...this is one car that needs it.
            Got the housing back from the welder's shop.
            Did some wire brushing and sanding. Keeping my fingers crossed for 40degrees tomorrow to do the cleaning inside and out. Can't have the torpedo heater running with those volatile fumes.
            13 F-150 XLT 6.2 l
              Got the rear painted and assembled it to check gear pattern. I smiled when the backlash was 0.012. The pattern was another matter.
              Hindsight being 20/20 it bugs me that I didn't put a 0.030 pinion shim in. I thought about it but decided to put in the 0.027 that was in it to begin with. Since I'm no expert, I'm thinking about trying the 0.030 and seeing if that gets me there. I have said before give me a 50/50 choice and I will choose the wrong one every time!
ID:	1273854Click image for larger version
ID:	1273855Click image for larger version
              13 F-150 XLT 6.2 l
                Havent keped up with the complete thread but a heads up. The weakest point of the rear end are the bearing caps are you using the stock ones?
                  Sorry to say just the stock caps. The only help is the aluminum cover/brace.
                  2nd try was a little better. I think it's about half way there. Wish I knew more about how much to change shim to get a desired effect. Thinking about going up by another .003 to total .033 and see where I'm at???
ID:	1273860Click image for larger version
                  13 F-150 XLT 6.2 l
                    There is so much win in this thread I don't even know what to say except... awesome job!!! This is what I love seeing done with boxes
                    1991 Grand Marquis LS blog- Mayhem; two 12" Kenwood 800w subs, True dual catback, BBK shorties, cherrybombs, steel top, L/H hella lights, 18" AR Torq thrust, Trans cooler, class 3 hitch kit, more on the way...
                      [ATTACH=CONFIG]38625[/ATTACH][ATTACH=CONFIG]38626[/ATTACH]
                      That looks better. That's about what the 4.10's I put in my 88 came out at (actually they were probably a touch worse).
                      At least with the whole axle out of the car tearing it apart again isn't as bad...
                        Well, here is number 3.
                        Still not enough. I'll try one more time at .036 Ugh! I just want the drive side closer to the toe and root.
ID:	1273864Click image for larger version
                        13 F-150 XLT 6.2 l
                          Pretty damn close though. I always hated setting up gears, even in the marine side of things. That's why I don't even try anymore lol.
                            I think the 3rd setup at .033 is the best.
                            This is the 4th try at .036 it seems to have gone too far.
Name:	4a - Copy.jpg
ID:	1273876Click image for larger version
Name:	4b - Copy.jpg
                            13 F-150 XLT 6.2 l
                              This is at .032 pinion shim. The backlash was reading .015
ID:	1273880Click image for larger version
                              Moved the carrier .003 to get backlash to .013. I wanted to get to .012 but those shims were not available. Stacking them just didn't work as well as getting the oem shims in one piece. I was shocked when they did have these sizes in stock at my local dealer. This is the final marking. I think pinion at .031 with backlash at .012 might be perfect but I just cant do it again. It got quicker and easier each time but not enough to do it all over again! lol
ID:	1273883Click image for larger version
                              Much happier with the brakes. They went on quite well. Everything is lining up perfectly. Made me happy since they sat for a few years in a box.
ID:	1273885Click image for larger version
ID:	1273886Click image for larger version
                              13 F-150 XLT 6.2 l
                                What calipers are those?
