what brand of paint did you use? i hope they make a ford blue
VHT I had left over from painting the new tranny on the 87.
Exhaust time!
Originally I was just going to slap on my extra pair of 90 TC manifolds, and just delete the mufflers, but then I remembered I have 3 pairs of factory stang headers and a factory catted stang H-pipe lying around. And as much as I hate how this thing fits, it should help waken up the lopo a little more. As for the rest of the exhaust, I'm just going to cut off the factory bell flange's on the H-pipe, weld on some tube, then some 45's and side exit's right before the rear tires.
Pic time!
Factory vs. new:
Headers mocked up:
Ill-fitting H-pipe mocked up:
Also bought it a brandy new battery at work today:
nice progress mang! i know i have said it before but, ill say it again... make sure you soak that car in a hellava oil bath lol.
Bah, looks like my exhaust plans are foiled, there is no way to fit a stock catted mustang H-pipe on a 90-91, the one cat jams into the shift selector cable and bracket. And attempting to massage the heat shield on the cat resulted in the cat falling apart.
So instead, a 2.5" no cats mustang H-pipe from summit, and 2, 26" asspacks will have to do.
Did the 3g swap today. I picked up this 3g at the junk yard back before I even bought this thing, finally decided to put it to use.
Took it all apart, cleaned and painted it, and reclocked it to sit like the stock 2g.
Installed:
Can just see the 175amp fuse attached to the solenoid:
Charging cable is just the stock one from the Taurus I harvested the alternator off of.
Charges at 14.2v @ idle, and 13.8 @ idle with everything on max. Not bad for a total of $20.
Not bad at all actually, just need to cut the turn downs down a little. H-pipe is even with the tranny pan, and the rest is much higher than the rear axle.
