Well my 85 'help me decide' post is sorting things so well in my mind I thought I'd do the same here, but with no possiblity of selling
More to do with priorities. Keep in mind I'll keep this car till it rots away.
So if you'll bear with me, and suggestions and comments are welcome! Maybe I missed something? I'm considering this my master list.
Here it is, the wholy crap do I really need to do this NOW list:
Important stuff:
*The slight wobble in the front end. The last thing I need is for it to throw my new tires out of round/wear on new front end parts. I don't want to reload the parts cannon but I did have a car that was constantly killing rotors and it ended up being a bad strut. So I consider rebuilding the suspension a very high priority. I've decided to go with the cop gasajusts front and rear, stock front springs, cargo coils in the rear. Anyone know where to get front coil spring insulators for this car? I can't find them, I'll have to call Ford.
I've got some wobble related choices to make while on this job:
-change the bearings? Problem is (like everything else on this car!) they're expensive (cheapest good ones I can find are over $70). So I'm thinking I'll use the mech's stethescope to listen in before ordering.
-change the LCAs? See expensive comment above. But I think this one's a very possible wobble culprit, and I'll never figure it out without changing it, so I might get a cheapie (??!) $125 dorman for the right side only and reuse the newer moog ball joint. This is seriously going against my first thought, that I should do both, but money is flying out the window and it makes me sad.
Other suspension related choices, will and money allowing:
-change the front sway bar links to 'good' units. I put cheapies on already, but I'll have to undo them anyway and I've had problems with these in the past, this is probably going to happen.
-change the front sway bar bushings. Almost a no brainer, as Energy greaseable polys are around $20 and I already have new bolts/clips. But, if I do all that I might as well:
-change the f&r sway bars to cop ones. I should have no problems finding them at pullapart and they aren't very much $. And I have new rear links already. If you can't tell I've pretty much talked myself into this. Hope I've got the $ at the time.
-rebuild the rear suspension completely. I'm going to have the rear shocks and springs out, and the driveshaft will be out too (for ujoints and rear trans seal which I already have) so I'm thinking I should change the rear watts link at least. Around $40 for a dorman/cheapie this will probably happen. I'd really really like to change the control arms but it's $70 for a cheap set and I've heard tell the 'good' upgraded sets ($3-400+) make a HUGE difference in handling. But everything'll be out of the way and the good ones are probably a pipe dream. On the fence with the cheapies, but I'm cheap
*Slight miss. It's driving me crazy. To recap, I've changed plugs COPs & boots and cleaned the heck out of the intake etc. I do have a KAM check engine code (low voltage - probably a broken wire, a known problem on these) and will pay to have that fixed first thing. If that doesn't solve it I'll either have the shop tell me what's wrong or look for it with my nephew.
*Occasional slight trans slip. I've changed the pan fluid/filter but will get a tranny flush.
*Belt system noise. I'll just have the shop tell me what's up when I take it in for the KAM. It does have a new tensioner and idler pulley.
*Rust. Boy does this go against the grain - it should be a low priority! But I'm starting to get rust on the inner door lips and what's the point of all this other crap if it rusts prematurely? My inner pollock is in conflict. I got an estimate last year at a very good shop, that I know is excellent, that place is like a car show. Not only would he fix the doors but also pull the rocker trim, fix any scratches flaws etc (of which it has many) and give it back polished and beautiful. It'd look like a new car and I know it. Problem is - $600! ('it'll give me 10 hours') Do it once, do it right? I might not be able to afford 'right'. I will get other estimates and if anyone has any suggestions in the Cleveland/Akron area I'm all ears.
That's it for RIGHT NOW problems. Since this is my 'master list' I'll add the other lower priority stuff, input still welcome:
*Interior. I've been sitting on a new interior for a bit and hope to install it this summer. Overall she's looking a little rough in there. But if I'm going to attempt the install myself I think I should do a few other things while I have the seats out.
-change the carpet. It's pretty ugly, I don't think a steam clean will be enough, and frankly it's not the nicest carpet anyway. Looks to be around $140 for the cheapies to around $190 for a 'super plush'. Plus floor mats, yikes! Maybe a cleaning will work.
-run stereo wires for future upgrades. No brainer with the carpet out, although I'll have to give the main power cable some thought.
-change the dash bit that says 'Grand Marquis' - it's warped.
-change the drivers' inside handle. I can't get it clean.
-change the master window switch, it's broken.
-change the pass side heating elements, no worky.
-get the headliner clean?? Might have to pay for that. Depressing.
-clean the rear package tray.
-it'd be nice to rewrap the steering wheel but that's probably a pipe dream
Looking at that, the interior might have to wait till '14.
Lastly:
*Factory stereo is starting to blink out
*Pass front window moves slow
*Change all orings in the (non op) AC system along with orafice tube and dryer, test
*Find and change the trunk liner
*clean the engine compartment
Whoa, I think that's everything? Thanks again for putting up with this
it really helps sort it all out.
Pete
Important stuff:
Lastly:
Pete
