A few miles on the second car I've put ceramic front pads on and I like them! Still a little chirp from the back brakes, the rotors and pad should (better!) be OK so I'll take them off clean and lube them when I pull the snow tires off Saturday (yay!). For my permanent record the front rotors ended up being a matched L/R pair.
Then maybe take the back rotors off and put them on the right direction
Still with the wobble, severely diminished but still present, working its' bad magic on my new stuff. I'm going to do what I should've done with the rebuild and replace the front LCA rear bushings, they are cheap and easy. Actually I should've replaced the LCAs in their entirety, and now Rock has Ray Prof ones for $155 + frt, but the bushings are cheap and I'm pretty broke. So I'll change the back bushing and then when that doesn't work change the arm. Nothing succeeds like doing the same job 2 or 3 times.
Still need to do the ujoints and rear window actuators.
Pete
Pete
