Random late update: Oil and gas gauges still wonky - I have an aftermarket oil gauge to put in... sometime. And i just put some gas in when the gauge needle leaves the full position and starts to pan back and forth, lol...
While putting in a new rag joint I bumped the PS reservoir bad enough to spin it around the pump a little and make it leak. 3 bottles of power steering fluid later, partly out of frustration, I twisted it back the other way with an angry grunt and reduced it to mild seepage
I never mentioned checking the compression while trying to fix the rough idle, #1 has about 50%. It smooths out once you get going so it doesn't bother me too much.
I just brought home goodies with it a few weeks ago!
