Originally posted by 1987cp
View Post
I have looked at quite a few options for an in tank pump, but none really provide the flow rate I am looking for, that are also submersible, and able to pull uphill.
I will be doing just what you said for modifying the pick up with a bulkhead fitting. I'm actually going to add two bulkheads, and cap one, just in case I decide to run a return system down the road.
For now, though, I am not going to use a return system. The pump I will be using is going to provide 6 psi, and doesn't recommend using a regulator.
Down the road if I decide I need a return, I can go that route. But for years cars used mechanical pumps with no returns, without issue.
What pump are you using that required the use of a regulator? Have you ever considered swapping pumps as opposed to running a return line?
