might be worth locating a limo rear. 31 splines.
The 89 CV LX
Nice trophy, and its a reson to upgrade.
Are you eventually planning on putting your KB in/on this car? If so, you may consider running less gear.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
The KB will most likely end up in the 87 CP as it is currently engineless. I had planned to do a DOHC 4.6 in it, but that will probably end up in my Tudor (way down the road....)2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Sounds good.
Typically, running a little less gear will help with engine load, which helps with building boost.
What pistons do you have in this engine?**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
What pistons do you have in this engine?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
I did something odd today and worked on this car.
I was sick of the seats from the 88 P72 kicking around, so I swapped them into this. For the first time in a long time the car has a complete matching interior. It even has rear seat belts again! I like the Bronco II buckets much better, but I need to redo them.
The police buckets are a bit faded, but what do you want for free?
Looking good. I also like the gauge pod, that is under the ash tray.
Time for this thread to be revived?__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Zach, may I ask where you got that carpet dash pad cover? I want one.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Originally posted by Bobcat View PostTime for this thread to be revived?
Originally posted by nfldfordltd View PostZach, may I ask where you got that carpet dash pad cover? I want one.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by pantera77 View PostThe sport box thread is where everything will be. A fresh start for this car.
IIRC I bought them through auto anything. I have one in my 85 as well, there made by Dash Designs and seem of good quality and fit.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
