My 1988 Crown Victoria LX 4 dr has been a long time obsesion project that most people i know say I'm crazy for it.
Drivetrain:
1972 LTD 351W .030 over
* Edelbrock 2182 Perf Plus Cam
* D3UE 302 Heads
- plained 52CC chambers
- ported and polished
- three angel valve job with 1.94/1.60 valves
- screw in rocker studs
- pushrod guide plates
- Roller Rocker Arms
* Cloyes Tru Roller Timing Chain Set
* Edelbrock Performer 600 CFM carburetor
* Edelbrock Streetmaster 351W Intake Manifold
* 14" x 4" round K&N air filter
* BBK 351W swap Shorty Headers
* HEI Distributor
* Nylon Flex-a-lite Fan
* Lokar AOD kickdown cable and throttle cable
* Mickey Tompson aluminum finned valve covers (love the vintage look)
~ Planning to get a Edelbrock Performer RPM intake in the future
Stock AOD transmition
* Stock stall convertor
~ when i have the money im going to get a 2200rpm stall and a shift kit
2.25" Dual Exhaust
* H - pipe
* Purple Hornies glasspacks
~ different exhaust when i decide what i want and have the money
Stock driveshaft
~ looking into possible upgrades
Rear axle
* Stock 1984 Towncar Signature 3L55 axle swap
- 3.55 gears
- Factory Ford limited slip posi unit
Suspension
* PI springs
* PI 1" rear sway bar and 1 1/16" front sway bar
Shown with Holly carb (couldnt get it to run right)
Body work / mods
* Carved up the shock hood and made it have 3" cowl
* Shaved antenna
* Shaved rear door handles
* Removed stock side mirrors and put Mustang II mirrors on (further forward)
* Slicktop Conversion
* Under the hood is already painted Bahama Green (hence the project name)
* PI 140MPH Speedo
* Tach mounted in dash where clock was
~ Planning to paint the car Bahama Green and maybe 2 tone with black or gunmetal
~ Planning to redo the deck lid (remove ford oval and redesign the liscense plate spot
~ Going to build a lip style spoiler
~ Working on design for custom tail lights
~ Working on design for custom grill (and possably headlights/beseals)
~ Wanting to get sideskirts
A few Sketches of what I'd like it to look like:
Let me know what you think and any ideas you have for I'm sure there is some good ones I havn't thought of yet.
Drivetrain:
* D3UE 302 Heads
* HEI Distributor
2.25" Dual Exhaust
* H - pipe
Stock driveshaft
Rear axle
- 3.55 gears
Suspension
* PI springs
Body work / mods
* Shaved antenna
* PI 140MPH Speedo
