Sly's Panthers
    Still haven't touched the Lincoln... maybe tomorrow... got the hitch for the vic in and on the car today.
    pics:
    mockup and drilling done
    all bolted up with the mangled mess of the bolt fish line on the ground (the last bolt didn't wanna go)
    done
      Originally posted by miamibob View Post
      And probably many phrases not found in the Bible!!
      Dobby's sock!
        90 TC fan shroud and tank are in the Mark VI now. Had to make brackets to mount to the non-stock radiator... but it fits... BARELY. The transmission lines that go to the radiator are mildly against the coolant tank after some persuasion, instead of blocking it. No more cheapo ugly ass universal coolant tank! WOOT!
          3-point belts installed in the back. That was a PITA and I burned up my Dremel in the process (bearings were already on their way out anyhow). Got a cheapy Harbor Freight one to finish the job. Went though about 5 Dremel metal disks in all.
          Anyhoo... pics:
            I kinda like the blue belts on the gray seats. How is the harbor freight dremel wannabe tool? I've been considering picking one up for a freind who's always borrowing my dremel.
            Axle codes
            Open/Lock/Ratio #
            G / H / 2.26
            B / C / 2.47
            8 / M / 2.73
            7 / - / 3.07
            Y / Z / 3.08
            4 / D / 3.42
            F / R / 3.45
            5 / E / 3.27
            6 / W / 3.73
            2 / K / 3.55
            A / - / 3.63
            J / - / 3.85
              it's actually pretty good. I got the variable speed corded one. all the dremel bits will work fine (comes with 1/8 and 1/16 collets). none of the attachments will work that require the square drive as the thread is different on the HF one.
              oh... FYI... the seats are beige/tan/faded... not grey. not that it matters... that interior is rather crap.
                Ironically, I keep saying our 99 is tan, and my wife insists it is grey. I looked up the color code for the interior, and she's right. It sill looks tan to me.
                Axle codes
                Open/Lock/Ratio #
                G / H / 2.26
                B / C / 2.47
                8 / M / 2.73
                7 / - / 3.07
                Y / Z / 3.08
                4 / D / 3.42
                F / R / 3.45
                5 / E / 3.27
                6 / W / 3.73
                2 / K / 3.55
                A / - / 3.63
                J / - / 3.85
                  Hotlinked pics no worky for me ... weird. I copied the URLs from the Reply With Quote dialog and had a look anyway.
                  Are you the first person to actually do this? I recall posting some time ago asking if it were possible, but this is the first time I know of someone actually adding shoulder belts to a pre-'90 Panther.
                  As for the mount points, were you able to find any factory provisions on the metalwork itself? Hopefully the mounting areas were at least well reinforced, even if the holes weren't drilled/tapped/squarehead-nut-on-a-plate-added-on-the-backside-like-for-other-belt-mount-points.
                  Anyhoo... pics:
                    the mounting points in the rear deck were not reinforced, but are double layer sheet... so most backseat riders should have no issues. The hanger is mounted with large 1/8" thick washers that are from electrical switch installations (those HUGE green boxes on the ground that carry 13KV electrical lines)... so they're grade 10+ or something obnoxious. There was a stock boss, but I would have needed to create an angled mount to get to that one and still be able to retract. I figure this setup is good for one full impact collision and would need to be rebuilt with the car... and I'd just strip it and scrap it at that point anyhow. And this setup won't be prone to people unbuckling while the car is in motion as the old constrictor lap belts are prone to being jacked with.
                      Weird, I've never known people to up and unbuckle with the car in motion.
                      Did you get a picture of this stock mounting boss you speak of?
                        nope. It may just be an un-used panel mount location too. It looks exactly like the other two that the sail panels actually use except there's no hole in it.
                          new sub enclosure... Polyfill wrapped in cheesecloth stuffed... same old speakers
                            found the rattle. the torsion bar rests on the box and when the trunk is shut, moves the contact point left of the factory sound deadener/pad. cut off a piece from the box I'm keeping and "fixed" the issue.
                            Also, put some on the fuel door to shut it up.
                              Nice sub enclosure! So the quest for eliminating rattles begins (or continues). That was a never ending quest for me with the Malibu. I ultimately failed as the amps and speakers have been in my old bedroom for 13 years.
                                I'm pretty much done finding rattles actually. I can't listen at levels that try to moderate your heartbeat, so the only rattles left ate in the taillights, rear license plate bracket, and lower door moldings. so meh. Can't hear those in the car anyhow. I could however hear the 2 I fixed.
