finally got the trunk to stay up on the Mark. seems the geometry on the lifts needs some adjustment... like the stock location is totally wrong. I made a temp-perm fix and will look at getting a mount point located on the wheel well, which would be better for the mechanical advantage.
The brackets are made of some punched angle steel. I folded it over to give it better rigidity (2 layers are better than one).
pics...
it even holds itself up at lower points too
I'll probably use a universal eyelet style bracket like this one: http://www.autopartsbylou.com/lift-s...item=to-brk285
pics...
