The '74's Replacement
    I park way out in the parking lots usually unless I'm driving the little bimmer. It does need 2 spots too.
    Resident diesel addict
      A few Daytime pictures I took due to neighbors saying my truck blocks the parking lot exit. Took some to show the property manager they are wrong...
        Sounds like you have lousy neighbors...
        '79 Continental Town Car
        '90 Crown Victoria LTD
        '94 Crown Victoria
          Neighbour probably drives a Chevy.
            Its the old ladies I have as neighbors, they all have nothing better to do then bitch and moan about everything.
              Originally posted by P72Ford View Post
              I think there is a way to bump up the line pressure by wiring in a resistor. I believe Ivan (Archangel) did that with his truck; maybe the E40d in yours is a later model, but he may be able to give you some advice on that.
              The resistor mod is easy to do but hard on the trans, therefore I would not recommend it. For that matter aftermarket kits like the B&M switch and the Banks TransCommand are nothing but overpriced resistors in fancy boxes and shitty wiring, despite what the respective manufacturers say.
              What this transmission needs is a TransGo Tugger or Sonnax SureCure shift kit, or a TransGo HD2 kit with a .427 or .500 Sonnax modulator valve, or you can even do like me and use a basic TransGo kit with the Sonnax valve and then you custom-drill your accumulator body separator plate for more feed into the pistons.
              Oh yah, nice truck dude, good buy!
