Sexy nice. Now hook up the lights!!!
My 1983 Mercury Grand Marquis LS 2-Door
i did not have high hopes for this when you first posted about it but it looks awesome so far.sigpic
Looks great2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
i have another extra gm cluster laying around when i find another lincoln town car digital cluster i can make someone one. i enjoyed making it so i wouldnt mind making some for you guys.
gonna find a way to rig up the turn signal light indicatiors and high beam light indicators without using the circuit board. thinking of putting solder on the the connectors should do it.Last edited by MattsLincoln; 07-02-2011, 10:39 AM.
1982 Lincoln Continental Mark VI Bill Blass Designer Series 2-Door(Larisa)-Mods: HO Roller 302, GT40P Heads, Explorer Intakes, HO ECM(D9S), Autodimming w/compass and outside temp rearview mirror, Daniel Stern Lighting Mod, Dual Exhaust, 90's GM C/K Series Retractable Hood Light, Red Digital Dash Display, 92-94 White Leather Town Car Signature Cupholder Armrests, HPP Wheels, Police PS Cooler, Police Trans Cooler. More to come!!!!
Matt,
You are the man for this. Should be even cooler when its all done and everythings working (Lighting, signals etc.)
Looks great though!1986 Mercury Grand Marquis "5.0" (160,000)
2011 Ford Crown Victoria "4.6" (54,000)
2015 Jeep Wrangler JK Willys "3.6" (48,000)
Originally posted by Georges86 View PostMatt,
You are the man for this. Should be even cooler when its all done and everything's working (Lighting, signals etc.)
Looks great though!
thanks. i really out done myself on this mod and it all paid off. now once i am ready for inspection i will hook up those lights. but that is going to be a few months after the engine swap is done. now gonna bu a set of 3 digital gauges for water temp, oil pressure, and voltage to mount under the ashtray. cost only $97.
Originally posted by 86VickyLX View PostLooks good. that flashing low fuel light would piss me off.
well when that blinks thats when i will fill up. so it doesnt bother me.
well since my order on the new fuel sender got cancelled. they dont have them anymore. i went to the junkyard to pull the one from the tc got it and decent shape i put it in and filled her up and the tank was pissing fuel from there. so i pulled it back out the seal came off the sender so i glued it on there and also put gasoline resistant silicone gasket maker around the hole to make sure it stops leaking will find out in 5 hours.
the fuel gauge works right and reads right now with the new fuel sender as i have half a tank of gas reading and that is exactly how much is in the tank when i reput in the fuel sender. so the mod worked i am very happy. pics later.
Originally posted by MattsGrandMarquis View Postwell since my order on the new fuel sender got cancelled. they dont have them anymore. i went to the junkyard to pull the one from the tc got it and decent shape i put it in and filled her up and the tank was pissing fuel from there. so i pulled it back out the seal came off the sender so i glued it on there and also put gasoline resistant silicone gasket maker around the hole to make sure it stops leaking will find out in 5 hours.
Originally posted by 86VickyLX View PostI forgot to ask you when I talked to you on the phone, you did spin the lock ring back on and hit it tight with a hammer and punch right? Just like you did to take it off.
yes i did. and it is locked in all the grooves.
looks like after scottfest marina is getting a badass cb radio going into her. cant wait.
