1990 country squire resto/lowrider in UK
    Your wish is my command!
    Welded in all the panels this morning but also had to patch a rusty and thin spot above them in the corner (went through with the media blaster). Quite difficult to cut it all out up there, but my trusty air saw came to the rescue again!
    I had to peel back the cargo area panel in the front corner and hold it up with a screwdriver so I could weld it.
    Any panels I won't have access to when it is all finished I etch primed and painted red (avoiding any flanges I need to spot weld soon) to prevent corossion inside
    I had to cut a good corner out to get access a few days ago
    This now needs closing off, so I made up a panel with a step/joddle and an overlap to try these new modern adhesives that some manufacturers use to bond panels on. Supposedly stronger than welding and seal the joints at the same time.
    Heres the panel
    and heres the glue
    Heres the new corner panel in place
    Lets see how strong it is in a few days.
    I used the same adhesive to bond a 1.6mm reinforcement panel to the top of the frame mount hole but will still tack it into place tomorrow to prevent shear fractures (twist).
    Compere the view now to what it was a few days ago
    Bit better!
    Andy.
    www.lowcamaro.com
      Awesome. I always wondered about those panel adhesives. Eager to see how it holds up.
        wow, I can't say I've ever seen this in-depth of a restore on a panther chassis car. Looks great.
          Managed to persuade a straight piece of steel to curve into the right place!
          Andy.
          www.lowcamaro.com
            Wow This is gonna be one sharp lookin car when she's done
            1980 Lincoln Continental Mark VI Signature Series
            351 4 bbl, AOD, 3.08 open
            duel exhaust with cherry bombs
              Originally posted by andyfanshawe View Post
              How long to get these skills? Started bodywork when I was about 19, and I'm 49 now. Thats 30 years practice. WOW!
              that's a bit discouraging to start doing body work on my cars
              Ont And Canada PPL The Cookhouse in Dwight
              91 Grand Marq . . . . . . 88 ho wagon (project) . . . . . . 80' Lincoln Mark VI
                Gotta start somewhere.
                  Don't forget that this is not my day job, so anybody with any enthusiasm could learn the skills a LOT quicker and produce good results very quick.
                  Learn to weld and bend steel in a vice, angle iron, hands etc.... , pick up some equipment bit by bit, and you are away.
                  Don't be put off. Get stuck in.
                  How much are you going to save in labour costs? And having the satisfaction of doing a job yourself.
                  I would quite happily help you if we were a bit closer!
                  Andy.
                  www.lowcamaro.com
                    I agree. The quality of work done here....even on parts of the car that no one will ever to see....I really want to see how this turns out.
                      Thanks guys.
                      Onto seat belt reinforcement panel replacement.
                      In the rear seat area the metal around the seat belt bolts is not good, Can't risk this, so out they come
                      Heres one already marked for cutting, with slots cut with the cut off wheel to get the air saw through
                      Heres my favourite tool of all time!!
                      Out it comes
                      Heres one I cut out earlier
                      New plate being joddled
                      Ready to media blast the rusty plate and weld on and weld back in
                      Andy.
                      www.lowcamaro.com
                        This is incredible stuff. I'm sure this car will bring about the phrase "better than new" a few times when it's done.
                          Managed to weld all 3 plates in
                          Andy.
                          www.lowcamaro.com
                            So THAT'S where I left my crayons!
                              That pic reminds me of when I first looked through my car. I found pencil crayons, happy meal toys, and this funny note from a little girl to a little boy about being mean. I should scan it sometime.
                              I can only imagine what would show up if I stripped it out to the point of re-welding seat belt mounting points. Wow.
                                Anyway, final bit of structural welding done today on the seat belt bolt reinforcing plates.
                                Media blasted them all and welded them back in,
                                This was the one above at the start
                                Then repaired the drivers and passenger front seats reinforcing panel.
                                Not bad since this is how it started out!
                                First coat of silver epoxy mastic 2 pack paint went on with a brush. Bit of a poor photo but I'll get better ones tomorrow.
                                Andy.
                                By the way, crayons have now gone!
                                www.lowcamaro.com
