1990 country squire resto/lowrider in UK
    The stress cracking around the body mount point doesn't surprise me all that much. If the mounts deteriorate, the body will move around more, causing flexing and fatigue. Its also just a high load area. Its probably also just not that strong to begin with.
      Had a sneak peek at the frame today since it was sunny!
      Finished welding in the repairs to the frame mount on the right and closed off the panel with my spot welder
      The seat belt reinforcement panel here is rusty
      Here it is removed. Too much rust underneath.
      Cut out the rust and plate made up to fit with a joddled edge. The numbers are for my good lady wife to push the panel with a pry bar while I weld it from underneath! I tell her the number and she pushes there!
      Over to the other side. Which I am expecting to be just as bad.
      In fact it was far worse
      Heres a view from the other side to show how far the rust has gone
      More welding to do then!
      Andy.
      www.lowcamaro.com
        nice work. its nice to see people putting in the nesassary work for a show car
          Cutting deeper to try and get to the end of the rust.
          Heres 2 photos to show the extent of the rust.
          The black lines are where the panels have been cut or is about to be cut
          Replacement panels have been made already and hopefully will be tack welded in tomorrow.
          Andy.
          www.lowcamaro.com
            Lets try to get this corner finally welded up so I can paint the underside and get the frame back!
            Heres the last cut on the black line shown above
            First panel made and tacked in place. Very very pleased with the fit considering it is going to be butt welded
            Trial fitting the front section. Yet another good fit! Bit of luck eh?!
            Different view
            I have designed these panels so I can have maximum use of my spot welder and get zero distortion and weld it FAST.
            The frame bolt hole will also be reinforced by the addition of a 1.6mm panel welded on top-just as I did on the other side.
            Quite surprised how well these home made panels fit. I must be getting good! How long to get these skills? Started bodywork when I was about 19, and I'm 49 now. Thats 30 years practice. WOW!
            I absolutely love doing this type of bodywork!!!
            Anybody want theirs doing next?
            Andy.
            www.lowcamaro.com
              Does this annoy anybody else as much as me!!
              Guess whats coming out next!!
              Andy.
              www.lowcamaro.com
                Nice work!
                I've toyed with the idea of removing the fold up rear seating area, then mounting an air tank, and an auxiliary fuel under there.
                When do you get your frame back?
                Axle codes
                Open/Lock/Ratio #
                G / H / 2.26
                B / C / 2.47
                8 / M / 2.73
                7 / - / 3.07
                Y / Z / 3.08
                4 / D / 3.42
                F / R / 3.45
                5 / E / 3.27
                6 / W / 3.73
                2 / K / 3.55
                A / - / 3.63
                J / - / 3.85
                  Andy.
                  no you are anal. I would just sand blast it, etch prime it, put some rustoleum on it and undercoat it.
                  but I just build junk to drive around, no where near what you build
                  but I also live in the rust belt too
                    Andy.
                    If its going to be a show car, then yes it would.
                    1985 GMC 1500
                      Originally posted by GoodSamaritan View Post
                      Nice work!
                      Hi
                      Frame has been back ages!!
                      Still wrapped up on back garden.
                      Best photo I have at the moment.
                      Andy.
                      www.lowcamaro.com
                        Heres the corner coming together.
                        The spot welder makes things very easy.
                        Andy.
                        www.lowcamaro.com
                          nice work!
                            You do beautiful work Andy, i'm amazed at the welding skills. The wagon is going to be great when you're done. Thanks for the frequent updates too
                              My pleasure sir!!
                              Andy.
                              www.lowcamaro.com
                                looks great mang can't wait to see more progress
