Will you go back and block out the roof with a nice long block and guide coat?
I dont want you to have a ripple effect in the paint on that LONG roof of yours by just using the da.
Already done that! Its as straight as its ever going to be. The rack that used to be on there has obviously caused some slight ripples around the mounting points halfway down that have reached over to the first pressing. Got about 10 hours in the roof plus a lot of paint. Gonna have to do! Its never going to be perfect, and I don't want it to be. Need to get this thing finished so I can drive it before I get too old. Lol.
Right,...the dashboard. That bloody heavy soddin thing! Jeez, thats a great lump! And since a lot of the wiring wont be needed (cruise, ac, heated windshield, etc) so remove and dismantle completely. Wiring loom out, unwrapped, unwanted wires removed (that took hours and hours to research), dash sprayed black, wires rewrapped and all put back together. Oh, one more thing. In the UK we have to have a rear fog light (for less than 100m visibilty) and a corresponding warning on the dash. So I've got to add one, or to make it cleaner, use one of the disused warning lights (airbag in this case) and rewire.
Top left one scraped clean
and painted yellow
Here's the back of the dash stripped out
and the metal bit
Here's the whole loom out on my makeshift wallpaper table on top of our bins!
Glad to see this thing still progressing! I remember when I narrowed and tucked the bumper on my ‘85 to achieve a similar look...it’s a massive waste of time on the earlier cars! Lol. Have any side profile shots of that bumper tuck?
'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Hi sick88tbird.
Side shot...
Front grille next. Plan is to turn it black, so framework made out of round tube bent and welded up ready for the black mesh grille to be wrapped round it.
Bits of the car going into paint this week, so frameworks made up to hold the front nose, the new centre grille and the headlight bezels
Bodyshell already epoxied and roof primed so that will be in for full priming soon. this week hopefully,
Back onto door cards......all 4 covered in black material
compare to old
Heres the old door handle pulls
and the newly designed
Since the car has no handles or locks, I need a way to pop open each door and wind down the rear tailgate window, so the CMD X remote controller bought from dakota digital, 7 relays and a 12 wat fuse box.
Mounts welded up, a plate fabricated and all wired up. Worked first time!
