hey andy also check down the inside of the panel.i had to repair my rockers and saw rust down there so check in there where the parking brake pedal is. looking good
1990 country squire resto/lowrider in UK
Looks good. Is there going to be any original Ford metal in this when you're done? Looks like you've replaced a whole lot of it86 Lincoln Town Car (Galactica).
Looking awesome Andy.~David~
All I can say is'88' MGM wagon (mine and my sons toy)
"60" chrysler New Yorker (my project)
"78" Chevy 1 Ton P/U (yard horse)
"01" Ford Explorer (wifes DD)
"93" Chevy Suburban (my DD)
Not had time to do much since my Wife did this to our Toyota Yaris on a pole
Bit of panel beating later and here we are
No cost so far, but got to fabricate a new rocker section tomorrow, the I can start to match the door to the rocker edge.
Anyway, back to the crown vic.
A cardboard template made to close off the top of the A post
and the exact same made of steel
Andy.
Meh... who cares about the Yaris... Get back to the good stuff!Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Last 2 sections welded in at the top of the A post awaiting grinding back and prepping for paint
And onto the bottom of the A post that looks bad...
But in fact, once cut back is not bad at all
Heres a view inside the rocker and one looking in just above the rocker
Doesn't look too bad in there.
Andy.
All cleaned up
Plate fabricated and hole drilled in the centre to get access for rustproofing
Plate and A post painted to prevent further rusting and spots where spot welds would be masked off first
Welded in
Rustproofed and seam sealed
And etch primed...
Not bad for a 21 year old car in rainy UK!
Here's the top of the A post sealed and prepped for etch priming tomorrow.
Andy.
Just god like you are Andy !!!!!!!'88' MGM wagon (mine and my sons toy)
"Godlike!" /Unreal Tournament
