Hi David.
Heres a photo of the energysuspension universal poly body mounts. One big washer up against the floorpan, the bigger black bush on next, then the frame, then the smaller poly bush, then the other big washer under that, then put the bolt and the tubes through and tighten up. No other spacers needed.
You can just about see the centre mount in this photo.
Any more info you need, let me know.
Andy.
Andy.
