So is the filler neck still removable?
1990 country squire resto/lowrider in UK
Originally posted by 1980c10 View Posthttp://qualityairride.com/content/2000-s10-daily-driver this has some good views of the hinges
Thanks.
Andy.
Originally posted by 1987cp View PostSo is the filler neck still removable?
Now I reach through the rear lockable compartment and undo both cap head bolts, then lossen the rubbery gasketty thingy (that I am going to fab to seal the inner wheel arch to the pipe) and pull the neck out of the tank and pull it through into the wheelarch.
Good question though. Thanks.
Andy.
This thread is worth that car's weight in gold from the pics alone.
Now I don't fancy butt welding this panel in. Too much chance of an irreplaceable panel distortion. So I am going to make a backing plate and spot weld the gas filler panel to it and then spot weld the whole thing to the quarter...
I had to use my spot welder with the long arms to reach into the top right hand corner
Love these photos! Looks like its got spots!
heres a view from the back
Andy.
If you were nearby I would always be over your shoulder learning as much as I can. I love the work you accomplish.
How do you like the rust/paint stripper wheel you have on your drill?~David~
Originally posted by 87gtVIC View PostIf you were nearby I would always be over your shoulder learning as much as I can. I love the work you accomplish.i just wish I had a place to learn basic skills that I could build on my own.
Hi 87gtVIC
If you are ever in the UK, you will be welcome to visit and have a good old british "cuppa" (cup of tea) with us! Your skills are not too shabby since your car looks damn fine!
That wheel is really good and effective. Bit pricey and shreds easily sometimes if you catch the edge of a panel and its rotating the wrong way, but it does its job well. Slightly scuffs the steel but gets rid of light rust easily. Far far better than any wire wheel attachment. Very impressed with it.
There is a brown version available that almost polishes the steel! Doesn't remove corrosion but roughens it up for an etch primer or equivalent.
Do you use these?
Andy.
Thanks Andy
I have not used the couple that I have at home yet. Good to hear that they work effectively if treated properly though.
-David~David~
Heres a view of the drivers quarter panel with all holes welded up and all glue residues removed. Took me about 2 hours with a panel wipe solvent and a flat bed sander to get rid of all the stickiness!!
I then started making card templates for the inner arch. Here the first one in place....
Here it is transferred to steel and a 90 degree flange welded on
and here it is clamped for a final trial fit.
Ran out of time then and got too late to do an grinding/welding so decided to strip the tailgate. Here it is with most things stripped off....
Looks a lot better!
I need to remove that lock and handle, so I will have to use a remote to mimick the action of the lock. One button to wind the window down, and a solenoid to pop the tailgate open. I will keep the interior handle so I can still drop the tailgate down.
Now I know this is a silly question and I know what the answer is going to be...whats the chance of getting a new tailgate window seal!!!!!
Andy.
Well if you find out I wanna know too.Originally posted by gadget73There is nothing more permanent than a temporary fix.
probably have to find some universal and trim to fit.
Yep, no American Squire owners have had any luck getting new tailgate seals. Its weird design is one of the biggest suckages of the Ford 3-way tailgate. The other, of course, being the 'gate's tendency to break and quit working in one or more of its functions. My big ambition if I end up keeping my Colony Park is to someday replace all that garbage with a proper tailgate like on a Range Rover or else a liftgate - something that actually works and is easily repairable if the window breaks or the latch goes wrong. There are people making replacement liftgates for Fox Mustangs out of fiberglass ....2012 Mazda5 Touring | Finally working on the LTD again!
I like the 3 way gate, just needs a better hinge and latch setup!!!!!!!'88' MGM wagon (mine and my sons toy)
"60" chrysler New Yorker (my project)
"78" Chevy 1 Ton P/U (yard horse)
"01" Ford Explorer (wifes DD)
"93" Chevy Suburban (my DD)
