Interesting developments on the airbag front
Heres a shot I took earlier on of a seriously corroded front centre sensor.
Heres the same sensor but with the metal peeled back
The silver circle is a rivet that should have been connected to the remains of the wire that is sticking out! So that is why the airbag ECU was detecting no earth through the circuit.
Here it is cleaned up a bit
So I soldered a wire to the little bit that was left and secured it back to the case with a self tapping screw.
The white stuff is a sealant to try to prevent it all happening again!
Then fully rustproofed (dinitrol 3125) and installed.
Guess what? After supposedly years of the airbag light being on, it actually went off!!
Too good to be true almost. Time will tell though.
Andy.
Andy.
