I have a really sleak way to install a voltmeter that just so happens to involve the flashing LED you are eying. Basically you will run direct power from the battery (to get the most accurate reading possible) to the voltmeter and for the ground, that will be connected to the empty pin of the relay (pin 87) so that the meter only work with the key in run or accessory.
1991 Grand Marquis
- Oct 2009
- 2878
- Keene NH
- Send PM
Nice I may think about that, but I am not sure I want to add any more gauges. I like the interioir as is."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
I understand. Your cars are not gauge friendly.~David~
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah even the modern tachs lack the elegannce and feel of the era, and that kind of stuff annoys me for some reason. We have a modern tach on our boat, because it needed a new outboard. Its a 69 starcraft, and that modern gauge in the wood dash just looks so out of place."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by 91grandmarquis View PostGotcha. Thanks.
Originally posted by 86VickyLX View PostIf you go the mechanical route, save yourself some headaches later and get the copper tubing and run that from the engine. Once away from the heat, now you can use the nylon stuff the gauge came with. You're gonna need more hose anyway.~David~
- Oct 2009
- 2878
- Keene NH
- Send PM
Im not sure I want to use these gauges anymore, If anyone is interested make me an offer. If they are any use to anyone on here. I think I want to keep the interior stock, except for the speedo and lighting."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Can you post up a picture of the back side of the gauges? I wanna see how everything is.~David~
- Oct 2009
- 2878
- Keene NH
- Send PM
Sure thing, after I get home though. Im in web design right now."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Ok here are the pics of the cluster per request....
1985 GMC 1500
yikes. I gotta pass on that.~David~
- Oct 2009
- 2878
- Keene NH
- Send PM
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by 87gtVIC View Postyikes. I gotta pass on that."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
are you getting rid of that vic cluster?
me rove you rong time.
it's the fuel gauge i want mostly but i'll take the whole thing if that's the way it goessigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
No Im only getting rid of the extra gauges, not the speedo, that is going in next weekend, sorry for any confusion."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
