hooray for HO parts!
1991 Grand Marquis
- Oct 2009
- 2878
- Keene NH
- Send PM
It isn't high heat paint on the plate so well see if it lasts, if not ill re do it when I get the HO on there. Any recommendations on what high heat paint to use on the intake itself? also I explained earlier how to get the raised letters to be painted, its not that hard, just takes a little prep, I think it took me like an hour to do the whole thing with 3 coats of either color paint. Plus I know a kid with a blasting cabinet, so I suppose that is a pretty good advantage."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by 91grandmarquis View PostIt isn't high heat paint on the plate so well see if it lasts, if not ill re do it when I get the HO on there. Any recommendations on what high heat paint to use on the intake itself? also I explained earlier how to get the raised letters to be painted, its not that hard, just takes a little prep, I think it took me like an hour to do the whole thing with 3 coats of either color paint. Plus I know a kid with a blasting cabinet, so I suppose that is a pretty good advantage.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
- Oct 2009
- 2878
- Keene NH
- Send PM
Ok I got around to mulling through storage (above the garage) and finding some of the parts that came with the car. My main question is about the cam shaft, will it work with the 302 and my plans for an HO swap. The rest of these pics is just for your viewing pleasure.
The cam and spec sheet;
The other parts;
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Ive also got some new front chromes and the original rocker chromes that came on her, just no pics. Im hoping to have all the trim on her by spring when the new wheels and tires go on. My main goal a of now is to get as much tread burnt off these coopers as possible. oh yeah and figure out whats going on with that cam too. I just dont know what kind of lift this engine can handle, the duration etc."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
wow your car is decent!
- Oct 2009
- 2878
- Keene NH
- Send PM
Ha thanks shes getting there."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
takes time mang.....i gathered parts for my ho conversion for over a year
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah Im not going to even think about having time to do the work until summer, when Im at least off from school, so Ive got the time. Im buying the heads this week, so after that its just the new computer, and maybe some headers, but I doubt ill have money for the H pipe so im thinking just leave it manifolds till then, although Id really like to get down to two high flow cats."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
score a used mustang or mk7 catted h pipe where you got the rest of the mustang stuff.....one is bound to come along cheap local
- Oct 2009
- 2878
- Keene NH
- Send PM
yeah thats what im thinking any recommendation on what headers to go with, Ie ones that wont leak, pretty much anything is going to be better than the pile of back pressure and restriction ive got now, I looked at the cat placement today while changing the oil, and greasing everything, and just started laughing, theres like 2 90* angles and then the manifolds, its a shame to do all that work to the engine and not give it the room it needs. Also bought new rotors, pads, and bearings for the front. There was now warning tab on these pads so I got the nice metal on metal grind as my notification, and I was keeping an eye on the pad left too, I guess not close enough. Oh well I just assume replace it all while im working on it anyway."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
