Progress was made! Today I replaced the fuel filter.... Swallowed about a half pound of rust in the process, went right in the throat so there was no spitting that could be done.
Moved on to drain radiator.... antifreeze is very sweet tasting.
Changed thermostat and gasket, installed new upper stainless hose and lower hose.
Discovered thermostat gasket did not seat right and was leaking... Replaced again... Discovered I had a new motorcraft upper and lower hose, so the one I purchased for $24.00 was completely unnecessary.
Filled radiator with water (again) and leak was fixed... this time it was the stainless hose. Tightened the hose clamp up.
Ran car to temperature to mix the water around, then drained radiator again. Left the drain undone, stuffed garden hose in the radiator and ran it to temp again... until water coming out was clear.
Stopped, let radiator drain, then filled with 100% antifreeze, then ran to temp again to mix.
10 hours later.... and down one set of clothes I am done. I am not sure why these simple procedures took so long. Oh wait yeah it was 90* outside today.
All bitching aside I learned how to do a radiator flush.. which was good. Now my dad wants me to do the Lincoln though.
Some pics of, well, not really much.
