My "new" little truck
    I've got a 87 F250 light duty 2wd has served me well for almost 5 years. Well the truck has almost 300,000 miles on the original drivetrain. I've decided to step up to a heavier truck. After some searching I found this beast.
    This morning I went and picked up my new tow rig. It's a 1991 Ford Superduty (basically a F450 ) 2wd dually. It has the 7.3L V8 idi diesel with a 5 spd, 5.13 geared disc brake Dana rear diff. It has leaf spring front suspension with a solid I-beam axle and 10 lug wheels. It has a 14,500 pound GVWR. It has a 14' flatbed with a built in full width storage box on the back. It runs good and drives good. It rides pretty rough empty like I knew it would.
    It does need a little work. It needs the inner rear tires replaced. The front fuel tank leaks and the rear tank filler neck isn't high enough so you can't fill the rear tank. And it has a couple other minor issues but overall I'm happy with it so far.
    It didn't have any spare tire so after I picked it up I ran to a salvage yard and bought a couple spare rims for it. I'm going to pull the BFG AT's off the back of my 87 and have them mounted on the Superduty rims.
    Here's a few pics of it. Sorry about the crappy pictures the batteries in my camera were almost dead. This truck is like the big brother of my 87.
    And here's what it's replacing.
    Good choice for a cheap reliable heavy-duty work truck. Know much about the IDI diesel? Oh yeah, your truck sits too level empty - need some more leafs in the rear
      Man I don't know squat about diesels period. About all I know about the diesel I've got puts out a shit load of black smoke when you get on it hard. And when you rev it over 2500 rpms the engine starts getting very loud!
      The only diesels I've worked on were VW rabbits/jetta's.
      It's a big change going from a F250 with a 302 that makes it's power higher in the rpm range to the low revving diesel that puts out a lot of torque.
      I've been trying to find out some info on the IDI's but I've got a lot to learn. If you have any tips or advice on them I would greatly appreciate it.
      Oh and if it had any more leaf springs I'd need a helmet! I just about hit my head on the roof when I hit a bump the way it is!!
        Thanks for the info. I'll register and start reading.
          That is sweet looking. You have TONS of room for parts and anything!
            Nice. I've always liked the early SDs.
            I believe they have 10 lug wheels (as opposed to 8 lugs on the 350).
            Also, I'm not sure, maybe you or Ivan could confirm, that the SD was not available in 4WD? My Dad always said that, but the maintenance department at my school has a later ('95-'96 I think) SD, with the 10 lug wheels, and it is 4WD.
              Nate, that is correct, the F-Superduty was never available in 4x4 from the factory, just like the 3500HD Chevrolets and GMCs. Any F-Superduty or 3500HD 4x4 truck is an aftermarket conversion.
                So are those doors on the side of the "bumper" how you access the taillights and wiring?
                  I haul a lot of scrap metal and usually I have to haul it on my 20 foot car trailer. Once I build the sides and rear gate, I'll be able to leave the trailer at home and just haul the scrap on the flatbed.
                  Me too. But I like almost every Ford truck ever made. This one is a beast! It's got everything I wanted to add on the truck I'm building and more. It's got the manual transmission, hydroboost brakes, 4 wheel disc brakes, transmission e-brake, dual rear wheels, plenty of room for storage. I plan on keeping this one for a long time.
                  Yes 10 lugs and some heavy ass rims! Hopefully I won't have to change them too often!
                  I've seen some 4x4 SD's but they were probably conversions. I wish this one was a 4x4! With the leaf spring front suspension a 4x4 swap would be pretty simple if it wasn't for the 10 lug wheels.
                  Those doors are for a storage box that runs the full width of the flatbed. And yes you can get to all the taillights and wiring inside the storage box. It gives me a great spot to store my floor jack and hi-lift bumper jack.
