looks ok pete I'm sure you can work your magic. the 91 was like that lol
Bought a '88 P72
It is solid looking Pete, slick top and all. Your should definitely keep it.~David~
I dunno... I might have a buyer for the motor and trans already, that will get me my purchase price back alone!
I'll have to see if I can make it run better and see what else it needs...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by 85crownHPP View PostI forgot to mention the "greasable" solid upper control arm bushings dont have any grease fittings... just plugs where the fittings should be... I hope they aren't wiped out.
no upgrades for this thing!
I sent Tiggie and the local guy Steve messages offerening it to them for 500 bux if they wanna come tow it away - offer is good for anyone else too in the area...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by Grandpaslincoln View PostYou guys.....you all have......BOX MADNESS!!!!!!!
i'd fix it up if the frame and body are good
Radiator looks like a 2 core... i forgot to pop the cap and have a lookey yesterday.
Well, I checked out the front end/steering, and its about as tight as a frog's ass. Just a cunt hair of play in a tie rod and one upper balljoint, which I think a few shots of grease took care of.
I couldn't get ANY noticeable movement out of the solid upper arm bushings - I pushed and pulled on the wheels and arm every which way i could, both with the corner supported by the frame and the lower control arm.
Its got new front pads on it, rotors look ok, the hoses are decent with just a little dry cracking.
In the rear brakes i found new shoes and new spring kits... one adjuster cable is broken, but we've got a bucket full of new/used brake hardware at work with a bunch of new cables in it...
I haven't gotten a good look at the frame/underside yet, but nothing jumped out at me while poking around underneath so far...
So.... looks like she will be with me for a while... at least until I try to fix the light-throttle stalling.
If i can do that, Im going to fix the brake line, put some temporary tags on it, and see how it runs down the road.
Dammit!!!
more money that shouldn't be spent... at least i can fool myself into thinking its an investment... maybe somebody will give me a grand for it down the road once i get it all fixed/cleaned up... yeah, "good luck" right?
If this thing turns up nice enough to keep I might try to sell the 91 instead.... but I hate to get rid of a fresh AOD and a 60K fresh motor...
It IS a disease!!!!!!!!!!!
I dunno, I kinda feel like this was destiny... just like when I got the 91 and the BII...
I remember when i fist worked on the car a couple times at the old shop and thinking "man, wouldn't it be nice if this were to be mine one day"...
This was about 5 years ago... then about 3 years ago the owner's business moved right across the street from my old shop where I could see it everyday... then it got parked for a year... then the business shut down... and now it is mine.
Looks like a good car, Pete. Those seats are damn nice too; had them in the '88.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Oh.... shit.....
It may be on like donkey kong. All sale offers momentarily suspended!!!!
I've just done some poking around under the hood, and noticed that the MAP sensor's vacuum hose is indeed collapsing shut, and the slightest wiggle makes the engine want to stall out.
The bugger is, both bad hoses are taffy all the way to the nipples deep under the upper intake, held on with rusty spring clamps
So Im about to go get some vacuum line and snatch the intake off later this afternoon!
I'm kicking myself in the ass right now, because i distinctly remember having a long piece of good red-stripe factory vacuum hose at some time, and its nowhere to be found now... i probably tossed it :nonono:
Might as well give it the PCV trio too. Valve cover gaskets aren't leaking too bad...
I'll be picking up a line and some unions, and renting the flare tool too... :heyhey:Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
*sigh* pete, you have it bad, man... the box bug has bitten you real bad... lol keep it... hell i can't afford the car right now anyway. tryin to get an apartment and finally get out of the parents house. so that's taking up most of my time, saving money... plus i just got Rosie not too long ago and we are still sorting out her little quirks. and i'm on vacation from work this week so if you want a hand with any of it, i'm pretty much free this week.88 CVPI - 5.0, lsc headers, punched cats, Cherry Bomb glasspacks, transgo shift kit, 3rd gen police console, 3rd gen push bar, KC Daylighters, wagon rear springs, soon to be 3.55 posi rear, all police antennas and spotlight, 216k on orignal motor, trans, and rear.
90 Festiva - 1.6 dohc turbo pushing 15 psi, full coil overs, 6 puck clutch. Daily whip that shits and gets. 30 mpg!
