grand marquis dashboard/instrument cluster installed! good times. I got everything I needed from the parts car except the A pillar from for 91grandmarquis It was broken
makes we want to go harvesting, but it's so darn muddy
the guy is basically only using the motor/trans, seats, speakers, and firewall from the car. he said whatever is leftover i can have. i got a multifunction switch
also, my car now magically has 70,000 km less than it did this morning
the parts car was also identical in color to mine...the only other one i've ever seen, same with the guy that owns it. interior color identical. it was pretty interesting to have them side by side to compare....some of the rear chrome trim on my car is hard plastic on his, and there are a few pieces of chrome on his where it's just nothing on my car. weird.
Did you swap an entire gauge cluster out? If so the odometer can be removed from the old one and placed in the new one. Thus reading the same. To change the reading you can take it apart and roll it back, but that is more work than swapping the old one in from the previous cluster. If that is what you did. If you're changing rear end gears you simply need to get a different speed sensor gear for it and the speedo to read correctly. Just a little confused on what you did is all.
Never mind I see you put a GM speedo in, so just swap odometers and you will be set.
"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles 1985 GMC 1500
sorry for the pic quality, my phone only has two puny mexapixels.
one of the pics shows the only gripe i have with the rain gaurds...it sticks out a little bit at the end. the thing must be bent or something because you hold it in place and the metal guard straightens out and looks normal. I don't really care, but yeah, you can see the holes for the posts that hold them in but I don't even havemounting location on my car for the posts.
1991 Mercury Grand Marquis LS - Current - June 2016 POTM Winner
1996 Mercury Grand Marquis LS - SOLD
1991 Mercury Grand Marquis LS - SOLD
1987 Mercury Grand Marquis LS 2dr - Long gone
