Originally posted by johnunit
View Post
My '90 LTD Crown Vic
he's the mechanic kitty. he reports no danger to teh manifold.sigpic
Originally posted by johnunit View PostNice cat, where are you installing it?Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
buy some better valve cover gaskets......the cork ones do not hold up well.....i would get felpro permadry gaskets
Originally posted by 1990LTD View Posttwo crappy pics of the new stance2012 Mazda5 Touring | Finally working on the LTD again!
my driveway/yard aren't even so no it's probably not on even groundsigpic
Originally posted by Lincolnmania View Postbuy some better valve cover gaskets......the cork ones do not hold up well.....i would get felpro permadry gaskets
I had oil leaking onto the exhuast manifolds within 2 years of using the cork ones.Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
thanks...right now cork gaskets will be better than leaky original gaskets. it'll get new rubber ones the next time i have the motor apart.sigpic
Ditto that... rubber is better than cork, but perma-dry is best (but expensive)... i think they were like 30 bucks when I got them for the 85... but the box was open, they had greasy fingerprints on them, so they gave them to me for half price!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
There's a 4000lb paperweight sitting in my driveway!!
Not a fucking chance I'm even going to turn the car over without the TV cable hooked up, so it's going to sit until I get the pieces I need.sigpic
Got the tv cable from the junkyard today. The cat that helped me take it off the car only charged me 10 bucks because I gave them the parts car in the first place
yanked out more smog/egr stuff today, but thought I made a mistake because the car would NOT idle properly afterwards. swapped out the new TPS I installed, still won't idle. Swapped out the IAC I installed....bingo. bad iac right out of the box. Emailed RockAuto about it.
It's amazing how much superfluous emissions garbage was on this car. I got rid of 3 solenoids (TAD, TAB, EVR), a pile of colored 1/4" vac hose and associated connectors (Ts and splices), and the vacuum hockey puck from up on the firewall.
I think the only things pulling vacuum now are cruise, brake booster, and fuel pressure regulator.sigpic
...and the MAP sensor, and the EVAP systemPete ::::>>> resident LED addict and CFI defector LED bulb replacements
